Antonis777
by Antonis777 » Sun Aug 24, 2014 10:27 pm
Sorry for bringing up the specific matter again, but I still got the same problem since Indigo 3.8.0. It stops working instantly after Sketchup finishes exporting the scene. Just to remind, this happens also with an empty scene. Using windows 7 32bit, Sketchup pro 2014. Any thoughts?
- Untitled - SketchUp Pro.rar
- (3.73 MiB) Downloaded 460 times
by Zom-B » Sun Aug 24, 2014 10:39 pm
And if you open the exported scene directly using Indigo, does Indigo then crash too?
Since you are one of the very few users having a 32bit System I suggest that the issue can be found in that direction...
Antonis777
by Antonis777 » Mon Aug 25, 2014 1:12 am
Zom-B wrote:And if you open the exported scene directly using Indigo, does Indigo then crash too?
It stops working even with downloaded materials from Indigo's website that have nothing to do with Sketchup at all. I thoughted too about 32 bit system causing this but Indigo 3.6.26 works just fine. Has there been a specific change in 3.8.-?
thesquirell
by thesquirell » Fri Aug 29, 2014 4:00 am
Hey there guys! I just wanted to say that I am thrilled over this mighty awesome renderer, and seeing it's support growing for all of the biggest 3D packages. I just have to say I am really happy that bundled IndigoMax comes with all the goodies now, but I have to say that there are some things really unclear to me (being a noob explains it). For example, IES profile: I am not sure if it's supported (and inside standalone it seems you can't create them). Exit portals: they are working as old portals did:nothing outside of them is visible. These things just come into my mind, and I'm struggling to figure them out. Seems like Indigo exporters for other apps took a bit bigger leap then the one for 3Ds, which is a shame, because I just love it. Sorry if I wrote all this in a wrong section, but seeing how Indigo works with other apps, and not being able to figure it out in 3Ds max, lead me to the thought that these might be bugs, even though it comes to me as if support for some of the features for 3Ds Max is still not available.
by OnoSendai » Wed Sep 03, 2014 2:09 am
Antonis777 wrote:Sorry for bringing up the specific matter again, but I still got the same problem since Indigo 3.8.0. It stops working instantly after Sketchup finishes exporting the scene. Just to remind, this happens also with an empty scene. Using windows 7 32bit, Sketchup pro 2014. Any thoughts?
Hi Antonis,
It's possible this may be an OpenGL problem. Can you try with the OpenGL preview disabled? (just close the widget with the x button).
by OnoSendai » Wed Sep 03, 2014 4:50 am
Please try the 3.8.11 build:
http://www.indigorenderer.com/forum/vie ... =1&t=13248
by OnoSendai » Sat Sep 06, 2014 12:51 am
thesquirell wrote:Hey there guys! I just wanted to say that I am thrilled over this mighty awesome renderer, and seeing it's support growing for all of the biggest 3D packages. I just have to say I am really happy that bundled IndigoMax comes with all the goodies now, but I have to say that there are some things really unclear to me (being a noob explains it). For example, IES profile: I am not sure if it's supported (and inside standalone it seems you can't create them). Exit portals: they are working as old portals did:nothing outside of them is visible. These things just come into my mind, and I'm struggling to figure them out. Seems like Indigo exporters for other apps took a bit bigger leap then the one for 3Ds, which is a shame, because I just love it. Sorry if I wrote all this in a wrong section, but seeing how Indigo works with other apps, and not being able to figure it out in 3Ds max, lead me to the thought that these might be bugs, even though it comes to me as if support for some of the features for 3Ds Max is still not available.
Hi there!
IES profiles are supported in Indigo. There is no UI support for them yet in the main Indigo UI though.
Exporter support for them in IndigoMax is being worked on.
thesquirell
by thesquirell » Sat Sep 06, 2014 2:27 am
Thank you very much, for your response mr. OnoSendai!
I see that Indigo works like a magic inside C4D, can't wait to see it working with 3Ds too! Actually, can't wait to see it working on everything and beign able to do anything! :D
by neo0. » Sun Sep 07, 2014 5:46 pm
Not sure sure if this is a big.. Well maybe it is but on my laptop screen (1366x768) some of the info is hidden. Namely this includes the @# of samples that have been completed on the render
by CTZn » Sat Sep 13, 2014 4:21 am
you will need to stack editors over one pile in order to provide the room for the display.
