Sun + background material, How it works?
9 posts • Page 1 of 1
DJ AntOn
Post by DJ AntOn » Mon Aug 11, 2014 6:24 pm
Re: Sun + background material, How it works?
Post by Zom-B » Mon Aug 11, 2014 8:06 pm
You forgot to put your EnvMap material into the "Background Material" field!
DJ AntOn
Post by DJ AntOn » Mon Aug 11, 2014 9:09 pm
please, example for Cinema 4D with texture
Post by Zom-B » Mon Aug 11, 2014 9:34 pm
check this image and find the empty box to put the EnvMap material in:
https://yadi.sk/i/lLARC6-1ZQJmC
Tipp: there is only one option ;)
DJ AntOn
Post by DJ AntOn » Mon Aug 11, 2014 10:49 pm
Only background, OK
sets:
https://yadi.sk/i/BM20Xsc7ZRHYe
result:
https://yadi.sk/i/EyxU7gwtZRHky
Sun + background, FAULT
sets:
https://yadi.sk/i/pcIA0XcFZRJCG
result:
https://yadi.sk/i/Ztnog3iVZRJiW
Where is background image?
How it works?
please, example
Post by Zom-B » Mon Aug 11, 2014 11:43 pm
DJ AntOn wrote:Where is background image?
You need to put your EnvMap into the EMISSION chanel, not the diffuse color ;)
Set it to uniform with a value of 10.000.000, the gamma to 1.0 and play with the B value to have it brighter or darker...
DJ AntOn
Post by DJ AntOn » Mon Aug 11, 2014 11:59 pm
don't work
https://yadi.sk/i/MFLZVP-1ZRace
please give me simple test with sets and texture for Cinema 4D
Post by Zom-B » Tue Aug 12, 2014 12:12 am
My fault, I forgot something!
You need to uncheck "captured simulation" and enable "Extra atmospheric"!
By this no Sky will be used, but only the sun.
At the moment you have the Sky and EnvMap blended together. Because the Sky is way brighter, you only see it, and not the EnvMap!
You can tweak the "Background material Weight" parameter to raise EnvMap overall power...
DJ AntOn
Post by DJ AntOn » Tue Aug 12, 2014 12:37 am
I am novice.
now it works
https://yadi.sk/i/xg7rSX6yZRj6h
could you say at the beginning?
thank you.
Users browsing this forum: Google [Bot] and 12 guests
