Indigo for Cinema 4D 3.8.6 Beta
11 posts • Page 1 of 1
Post by fused » Fri Jul 25, 2014 10:02 pm
for Indigo Renderer and RT 3.8.6
Windows:
Indigo Renderer:
indigo-for-cinema-4d-3.8.6-installer.exe - Includes installers for R10 - R15
Indigo RT:
indigo-rt-for-cinema-4d-3.8.6-installer.exe - Includes installers for R10 - R15
Mac:
Indigo Renderer
indigo-for-c4d-3.8.6-R105-mac.zip
indigo-for-c4d-3.8.6-R11-mac.zip
indigo-for-c4d-3.8.6-R115-mac.zip
indigo-for-c4d-3.8.6-R12-mac.zip (R12 version works with R13)
indigo-for-c4d-3.8.6-R14-mac.zip (R14 version works with R15)
Indigo RT
indigo-rt-for-c4d-3.8.6-R105-mac.zip
indigo-rt-for-c4d-3.8.6-R11-mac.zip
indigo-rt-for-c4d-3.8.6-R115-mac.zip
indigo-rt-for-c4d-3.8.6-R12-mac.zip (R12 version works with R13)
indigo-rt-for-c4d-3.8.6-R14-mac.zip (R14 version works with R15)
Changelog:
* Added support for null material emission.
* Added spherical camera support (Indigo camera tag > Spherical camera).
* Fixed bug in animated texture handling.
* Using 3.8.6 Indigo SDK.
kklors
Re: Indigo for Cinema 4D 3.8.6 Beta
Post by kklors » Fri Jul 25, 2014 11:07 pm
Yeeey thanks for the spherical cam <3
Umblefugly
Post by Umblefugly » Sun Jul 27, 2014 4:02 pm
Nevermind... :)
Post by pixie » Sun Jul 27, 2014 8:25 pm
When I set the null emission material to a 2nd layer it gives me this error. The first layer is used as background material.
Post by zeitmeister » Sun Jul 27, 2014 11:57 pm
Great update!
The big But:
there has to happen something with animation export.
C4d-Changed textures (by layer- or filter-shader) are exported for every frame. That means that of you export 100 frames, baked textures are exported 100 times instead of being referenced.
Not when rendering in c4d, but in the standalone, for sure.
Grüsse, zeiti
kklors
Post by kklors » Tue Jul 29, 2014 1:37 am
zeitmeister wrote:Great update!
The big But:
Just tested it again in the hope it was working, but the layer or filter shaders are still bugged. When you apply them it rescales the image to 1:1 ratio and I think to 512x512 or something low res in that direction. You can see that cklearly when you apply a layer shader to an HDR environment.
Post by Zom-B » Tue Jul 29, 2014 2:49 am
zeitmeister wrote:there has to happen something with animation export.
Just tested it again in the hope it was working, but the layer or filter shaders are still bugged. When you apply them it rescales the image to 1:1 ratio and I think to 512x512 or something low res in that direction. You can see that cklearly when you apply a layer shader to an HDR environment.[/quote]
I suggest the problem with baking textures for every frame is due to new animated texture support...
This behavior should only be showing up if you alter a loaded picture sequence with enabeled animated texture with a shader.
kklors wrote:Just tested it again in the hope it was working, but the layer or filter shaders are still bugged. When you apply them it rescales the image to 1:1 ratio and I think to 512x512 or something low res in that direction. You can see that cklearly when you apply a layer shader to an HDR environment.
You should be able to control the target baking resolution for every material in the "Extra Options" area under "Blend"...
kklors
Post by kklors » Tue Jul 29, 2014 3:03 am
Haha thanks, didn't know. Could have tried this one myself instead of noobing around : D
Post by zeitmeister » Tue Jul 29, 2014 7:34 am
... That for I set the Resolution already quite low.
Another thing:
There exists a function for altering color on instances, right? Or did I remember that wrong?
It would be so cool having that function as a shader in Cindigo...
Post by Zom-B » Tue Jul 29, 2014 7:50 am
zeitmeister wrote:There exists a function for altering color on instances, right? Or did I remember that wrong?
If your master has no material applied, you can have some on your instances and they work!
Polygon selections for multiple textures work that way too...
