light
5 posts • Page 1 of 1
horpa
light
Post by horpa » Fri Jun 13, 2014 9:03 pm
Hello,
I play with light.
bacon
Re: light
Post by bacon » Fri Jun 13, 2014 9:11 pm
Nice, but it seems your tv doesn't have the function for auto-adjusting light to environment ;)
Offtopic the sofa seems to have to low-res texture?
Re: light
Post by Zom-B » Fri Jun 13, 2014 9:32 pm
Nice stuff horpa!
Here are some tipps to enhance your work even further:
- For the TV use a dark phong material, and enable the texture only to be the (not to bright) emitter, by that you'll gain a more realistic look.
- The chairs look like having some veeery bright white, set them only to have a RGB value of max 204.
This rule is also for textures (like the magazine on the table)
- The room still have some quite dark walls & ceiling in some images, boost the tonemapping by using "agfapan-apx-400cd" and a whitepoint of E
- The couch beeing that close to the camera really looks very... simple! maybe you can find (or buy) a better one, otherwise change the tiling on it, the texture is too big. Also having some small DOF blur could "hide" the quality of that close up Object a bit.
- The floor looks like out of plain wood, try some higher quality textures here...
horpa
Re: light
Post by horpa » Fri Jun 13, 2014 10:30 pm
[quote="Zom-B"]
thank you for your advice - I try everything ...
M-Pixel
Re: light
Post by M-Pixel » Thu Jun 26, 2014 1:35 am
Hi ..
Nice Szene and render.
I like the first one *light*
