Layers Panel
5 posts • Page 1 of 1
jiminy-billy-bob
Layers Panel
Post by jiminy-billy-bob » Mon Mar 10, 2014 6:32 am
Some of you may already know it, but for those who don't, I want to introduce you to my plugin Layers Panel.
http://sketchucation.com/plugin/751-layers_panel
The main reason I'm posting it here is for its render feature that can be very usefull for people doing rendrings inside Sketchup. Here is a short video (Made with Vray but it works the same with Indigo)
http://www.youtube.com/watch?v=o62le_MUUZQ
Let me know what you think, and if you have ideas for other features.
Re: Layers Panel
Post by Pibuz » Mon Mar 10, 2014 8:38 pm
This plugin is really smart! Thank you!
I haven't tested it yet (BUT I WILL), but may I ask a question?
One of the problems I encountered using layers is that objects which are put in a hidden layer cannot work as referencies for other objects, while simple hidden objects can. Working with Indigo, this is typically the case of dummies:if the complex tree is on a hidden layer the geometry isn't exported so your dummy doesn't get the reference and cannot be substituted; if the complex tree is simply hidden, the dummy works as it would.
Does your plugin allow this kind of trick?
Thank you!
jiminy-billy-bob
Re: Layers Panel
Post by jiminy-billy-bob » Tue Mar 11, 2014 7:01 am
It should, yes. A layer with its teapot active is sent to the renderer. Is that what you're looking for?
lape
Re: Layers Panel
Post by lape » Tue Mar 11, 2014 8:45 am
thank you! I will give it a try!
24 hours isn't enough
http://www.werkraum3d.com
fenerolina
Re: Layers Panel
Post by fenerolina » Wed Mar 12, 2014 1:20 pm
Will certainly have a look, very welcome plugin! thank you billy bob.
