Where to start?
Announcements, information, requests and support regarding other exporters and general/new exporters
5 posts • Page 1 of 1
Kreten
Where to start?
Post by Kreten » Thu Feb 15, 2007 9:54 pm
Grettings!
Where to start.
Introdctions, tutorials, simple scene setup...
I read that "Indigo does not need any render parameters like GI samples, AO samples, AA samples, Soft shadows, etc, and complicated lighting setups to achieve realistic results" wich I read every F... day in other forums how to setup this and that and its just sooo :evil:
If this is true I would like to get involved with Indigo...
Where to start?
mattiasdh
Post by mattiasdh » Thu Feb 15, 2007 9:57 pm
install a quadxeon network :P
no just kidding, just try it out. i think the problems you'll encounter will be mostly from the rhino link which atm doesnt translate everything how it should into the indigo format. Apart from that it is true that you'll need a little more patience than with biased renderers..
Kreten
Post by Kreten » Thu Feb 15, 2007 10:12 pm
You badass :lol: !
But I have a small network farm :twisted:
Mattias what about tutorials for Rhino users, workflow egsamples...
And is this true abouth its simplicity and not having so much frustarting parametars?
Kreten
Post by Kreten » Sat Feb 17, 2007 2:05 am
Wrong place to post questions?!
Post by Zom-B » Sat Feb 17, 2007 7:24 am
Hey dude, you are totally right about the simplicity of Indigo,
because Indigo is a unbaised renderer it simulates real light,
so you simply can't do anything wrong it will always look real ^^
You still will need a good setup, just like a photographer...
The only functionality that isn't very easy to understand and use is SSS & Dermis/Epidermis stuff
in the 0.7 test builds, but its still in development...
I don't know how much Rino+Indigo Users are out there who can help you.
If you are used to blender or own C4D, Maya or 3Dmax try your first steps there because of the bigger community.
In your case I would just start with latest stable 0.6 version, rendering a single Object,
covered with a NK material (for perfect physical correctness :wink: ) of a metal like gold silver etc. in a cornel Box using BlackBody light
to get some feeling for the results....
after you learned how to setup your 3D App for Indigo Export,
just try some more complex Scenes you did before to render in Indigo.
Users browsing this forum: No registered users and 141 guests
