indigo 3.6.26 crashing when rendering caterpillar
7 posts • Page 1 of 1
Darshan
Post by Darshan » Wed Jan 29, 2014 12:26 am
As mentioned above I am running in win7 ultimate 32bit. when I render with Aperture diffraction it crashes in my pc showing "Indigo.exe had stopped working". I tried trial rendering of the caterpillar (which is in test scenes) at that time also it shows the same as above please help me what to do. I am currently using indigo for sketchup and blender. :cry: :?:
Re: indigo 3.6.26 crashing when rendering caterpillar
Post by Zom-B » Wed Jan 29, 2014 1:43 am
Double check the RAM usage of the rendering scene. Activating aperture diffraction is quite RAM consuming, and might result in a crash if you lack memory on your system.
32bit systems are also limited to a maximum of 4GB per application, for some even only 2GB. I actually have no idea how Indigo behave there, 32bit systems are rare in that business... if you ever update, go for 64bit!
Darshan
Post by Darshan » Wed Jan 29, 2014 8:06 pm
i hav 4 gb ram + nvidia gforce 2gb graphics .... i render maximum 1366x728 resolution. ( it a laptop)
yonosoy
Post by yonosoy » Thu Jan 30, 2014 3:02 am
Hi.
Please do this single test.
Open indigo gui.
Load caterpillar scene.
Found branch_phong material and deactivated the displacament (has an ISL texture).
Launch the render.
(This is from memory and not sure if is the same case, if works without apperture nevermind...)
Darshan
Post by Darshan » Sat Apr 05, 2014 1:03 am
that worked man... :D .. i want to know why it was happening...?? shaders are not running well in my pc... :?
yonosoy
Post by yonosoy » Sat Apr 05, 2014 10:06 am
Hi.
Only two months later... :lol:
If you want to basicaly run with 3.6.26 and windows 32-bits or linux 64-bits it´s suggested to replace the file ISL_stdlib with the one from 3.6.16 version (is the last that works). The fact is that in this distributions the "core" of the program seems to be the one from the 3.6.12 version (almost this is shown in the overlay info and console mode). In this way, the new ISL functionalities will be lost (multifractal function as example) but all the code before works fine; as the shaders do ! (hope).
This behaviour don´t occurs in 3.8.(0-1-2) ...
Thanks in advance.
EDIT: WINDOWS 32 bit compilation is allrigth for 3.6.26 (waiting for a confirmation in linux 64 ( could be a local problem)) and this crash is not related atm with this suggestion.
Darshan
Post by Darshan » Sat Apr 05, 2014 4:10 pm
indigo 3.8 beta or 3.6 confused :?....i should upgrade or not...???
