Renamed Model Materials, No Longer Renders
Hello all, new to anything and everything 3D related. I renamed, outside of SketchUp and/or Indigo, the materials used by the model. Now, when I export using Skindigo the rendering appears to run, but the preview image remains steadfastly black. Any help would be appreciated.
Re: Renamed Model Materials, No Longer Renders
When you say "the preview image remains steadfastly black" do you mean the whole scene or just the particular materials in question?
If it's the whole image it may be an incompatible GPU issue. If you have enabled GPU acceleration and your card is not compatible you get this result with the render appearing to run but nothing but a black scene. Try unchecking this box (if it's checked) and see if that helps.
If you could post a screen shot it may help
