SkIndigo 3.6.25.3 (beta)
2 posts • Page 1 of 1
Post by OnoSendai » Tue Nov 12, 2013 1:11 am
Hello,
This version just reverts the change in 3.6.25.2, which was causing problems with instances + components. :)
Also fixes a problem with exporting animations.
This is a beta release - please test. Please install Indigo 3.6.23 or newer before this version. Get it from here: http://www.indigorenderer.com/forum/vie ... =1&t=12606
To Install:
1) Download RBZ file from link below
2) In SketchUp, go to Window->Preferences->Extensions
3) Uncheck the SkIndigo checkbox, press OK, restart SketchUp
4) In SketchUp, go to Window->Preferences->Extensions->Install Extension
5) Select the RBZ file you downloaded
6) Check the SkIndigo checkbox again.
7) Restart Sketchup again.
NOTE: this elaborate process is to make sure the asset files get updated properly, which doesn't work if the extension is enabled.
Changelog:
#Version 3.6.25.3
#Reverted fix in 3.6.25.2 for infinite loops as was causing issue with instances in components not exporting properly.
#Fixed error when exporting animations.
http://downloads.indigorenderer.com/dis ... 6.25.3.rbz
bubs
Re: SkIndigo 3.6.25.3 (beta)
Post by bubs » Tue Nov 12, 2013 10:39 pm
Cheers Ono! All seems to be working fine now.
Users browsing this forum: No registered users and 70 guests
