Indigo 0.7 test 5
Indigo 0.7 test 5
This is a barely tested release, i just wanted to release something with Indigo Image (.igi) export so that people can mess with the tonemapping prog.
Enable save_igi in inifile.txt to export igi files.
I've also added the much-requested resume feature (barely tested)
use like this:
indigo.exe -r renders/some_igi_file.igi
v0.7 test 5
* Added .igi export
* added resume from .igi feature (-r)
http://www2.indigorenderer.com/montecar ... _test5.zip
use like this:
v0.7 test 5
* Added .igi export
thank you master ono.
edit: I LOVE IT!!!
- Kosmokrator
OkOnoSendai wrote:I'll make it obey the output file name for next release
Ps.
3 more things that i instantly started to miss and can't be done at the moment:
a) can't define a path for igi via commanline (like it is for regular output using -o pathname)
b) IndigoToneMapper.exe doesn't open igi from commandline (like tonemapper.exe some_igi.igi
c)<save_igi>true</save_igi>
Ps2.
Resume feature is just awesome !!!!! Works like a charm!!
- drBouvierLeduc
- VictorJapi
This clip should be from a Finland TV show where they teach how to disco dance. I have the show somewhere on my harddrive. It's from late 70's or something like that.. Pretty funny
[edit]
Yep, same show
Suvakas
[edit]
Yep, same show
Suvakas
VictorJapi wrote:C'mon and dance with Disco Utah baby!!!drBouvierLeduc wrote:resume fonction + tonemapping gui : splendid.
-->Camox : I had to say something about your avatar... it's... you know... rockn'roll (not sure what I wanted to say, but I said it)
