change path for igi and png
5 posts • Page 1 of 1
lape
Post by lape » Sun Aug 11, 2013 1:21 am
Is it possible to change the path for the igi and png files? It doesn't seem to be possible in the sketchup output settings. Its's just because I use a SSD, and saving the igi to the default render folder gives me a lot of bytes written, so I fear about the lifetime of my SSD... :(
24 hours isn't enough
http://www.werkraum3d.com
dag
Re: change path for igi and png
Post by dag » Sun Aug 11, 2013 3:14 am
Your SSD will outlive you. Nothing to worry about.
http://www.digitalversus.com/ssd/samsun ... 30201.html
lape
Post by lape » Sun Aug 11, 2013 11:44 pm
dag wrote:Your SSD will outlive you. Nothing to worry about.
Sorry, but I don't think so. After only one project, I already have 5.0 TB written. Just because I use the "save igi" option. Samsung writes something about 240TB, after this you will get problems. Seems I will reach the 240 TB after about 48 projects. If I work on 12 projects a year, the SSD will get problems after 4 years. And I'm not only using Indigo. Other software also write bytes...
What do you think?
Post by OnoSendai » Mon Aug 12, 2013 1:24 am
If you get a recent Indigo beta (e.g. 3.6.19) you can change the render folder used in the options dialog.
lape
Post by lape » Tue Aug 13, 2013 2:42 am
OnoSendai wrote:If you get a recent Indigo beta (e.g. 3.6.19) you can change the render folder used in the options dialog.
ok,thank you :D
