HELP: looking for texture
Come here for help & support.
6 posts • Page 1 of 1
Post by Pibuz » Sat Jun 15, 2013 4:47 am
Hi guys!
First time in my life I have a window just beside the POV, so I can see the small metal element which keeps the two or more glass panes detached from each other..
You know what I'm trying to describe?..
Do you guys have any good texture for that?
Thanks a lot in advance..
galinette
Re: HELP: looking for texture
Post by galinette » Sat Jun 15, 2013 5:37 am
Hi Pibuz,
I have this, not perfect but correct. To be used with an aluminum material. If you don't have an extreme closeup, should be OK.
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Post by Pibuz » Sat Jun 15, 2013 5:45 am
HMMMM! Seems exciting! ..have a reference image of the final result, so I can understand the scale?
SORRY TO BOTHER! :oops: :oops:
galinette
Post by galinette » Sat Jun 15, 2013 6:00 am
The spacer is normally 16mm thick on modern glazings. The width of the image corresponds to the thickness; so the other one repeats every 5mm or so.
Etienne
galinette
Post by galinette » Sat Jun 15, 2013 6:22 am
The material is often aluminum (use a specular with nk data, with some exponent to tune), but sometimes, it's also a black paint (such as in my current flat)
Etienne
Post by Pibuz » Mon Jun 17, 2013 9:10 am
Thanks a lot Etienne! I'll try those as soon as possible!
