Multi GPU
15 posts • Page 1 of 1
ravenzep
Multi GPU
Post by ravenzep » Mon May 13, 2013 9:01 pm
Hello!
When is that coming? We are in the middle of 2013. And i see on the forum its been mentioned sometime in 2011. I mean for us users that have multiple gpu. It seems that this renderer isn't quite "cost effective" now is it?
LuxRender can already do MultiGPU bi directional rendering. :)
Re: Multi GPU
Post by OnoSendai » Wed May 15, 2013 5:50 am
Hi ravenzep,
We are working on having the capability in Indigo to do almost all of the computation on the GPU. When we have this multi-GPU support will work much better and should follow shortly.
Until then there's not much point as the CPU is usually the bottleneck.
ravenzep
Re: Multi GPU
Post by ravenzep » Wed May 15, 2013 9:28 am
Thats bloody Fantastic. Will it be able to handle large datasets / meshes? Or is it bound to GPU memory like the rest of the GPU renderers?
Re: Multi GPU
Post by OnoSendai » Wed May 15, 2013 9:39 am
It will definitely be bound to GPU memory at first. We may look into something more complicated later :)
ravenzep
Re: Multi GPU
Post by ravenzep » Wed May 15, 2013 9:43 am
But why not let Indigo customers decide if they want to render out of core or not, based on scene size :)
Small scenes = fast , BIG scenes = a bit slower
Juju
Re: Multi GPU
Post by Juju » Wed May 15, 2013 11:21 pm
ravenzep wrote:But why not let Indigo customers decide if they want to render out of core or not, based on scene size :)
you already have the render affinity choice, CPU or GPU. CPU handles all render type options, GPU only a few.
ravenzep
Re: Multi GPU
Post by ravenzep » Thu May 16, 2013 1:52 am
What you don't know is that OpenCL on the CPU runs faster than pure C++ on the cpu. LuxRender proves that pretty good.
Re: Multi GPU
Post by Zom-B » Thu May 16, 2013 3:29 am
ravenzep wrote:What you don't know is that OpenCL on the CPU runs faster than pure C++ on the cpu. FluxRender proves that pretty good.
No it doesn't!
Re: Multi GPU
Post by PureSpider » Thu May 16, 2013 11:36 pm
What LuxRender proves is that their devs can fool their users pretty well 8)
galinette
Re: Multi GPU
Post by galinette » Fri May 17, 2013 12:09 am
An example is not a proof...
Also, since OpenCL on the CPU is, internally, a pure C++ implementation, we could rewrite the sentence "¨Pure C++ on the cpu runs faster than pure C++ on the cpu", which sounds weird :)
No it doesn't!
Well sometimes it does, if the base c++ implementation is poorly optimized. OpenCL tends to force to think parallel, which sometimes helps.
Eclat-Digital Research
http://www.eclat-digital.com
ravenzep
Re: Multi GPU
Post by ravenzep » Fri May 17, 2013 12:57 am
Gotta love when artists talk about C++...
Anyway Multi GPU isn't coming anytime soon for Indigo users :)
Re: Multi GPU
Post by OnoSendai » Fri May 17, 2013 1:52 am
Show some respect to the forum users ravenzep, or I will ban you.
William
Re: Multi GPU
Post by William » Fri May 17, 2013 2:30 am
Luxrender doesn't have full opencl rendering mode anyway. It has hybrid path rendering with opencl (ray intersections).
Then it has a completely seperate render engine called SmallLuxGPU (SLG), which is an opencl engine with a smaller feature set than that of Luxrender (but samples much quicker) and reads Luxrender scene files.
Luxrender is pretty good engine but it's slow (even with hybrid). Indigo probably 2-3x quicker (or more in some cases).
galinette
Re: Multi GPU
Post by galinette » Fri May 17, 2013 4:14 am
ravenzep wrote:Gotta love when artists talk about C++...
And, you know, I'm not even an artist 8)
Re: Multi GPU
Post by CTZn » Fri May 17, 2013 9:26 pm
Brag not, you senior coder !
