Texturing Ivy in Blender and exporting to Indigo
4 posts • Page 1 of 1
thednx
Post by thednx » Mon Mar 04, 2013 9:03 pm
i am having a blast with the Ivygen Plugin in Blender, and the results are fantastic.
The following problem shows up in my "workflow", so maybe someone has a cool tip:
Unwrapping a generated ivy so that i can assign a material is either -very- time intense or it doesnt work.
(blender hangs)
My steps:
1. create a mesh
2. let an ivy grow at selected mesh
3. select the leaves, go into edit mode und UVUnwrap.
4. Blender takes several minutes until finished, or crashes.
5. then, -if- all goes well, i can assign it a material...
Is there a way to handle texturing a high amount of objects (with the same material) and exporting to Indigo?
If i leave the ivy "as is", Indigo of course says that no uv coordinates were found.
Re: Texturing Ivy in Blender and exporting to Indigo
Post by StompinTom » Mon Mar 04, 2013 11:57 pm
thednx wrote:Hi,
(blender hangs)
My steps:
1. create a mesh
You can try going U (Unwrap) -> Reset, but otherwise I'm afraid you may be shit out of luck. UV mapping of the ivy leaves should be done by the script and it should already give it a separate material. If you use the IvyGen standalone program, I believe it UV maps both the leaves and the vines correctly.
thednx
Post by thednx » Tue Mar 05, 2013 11:18 pm
Wouldn't You know. Using the standalone script and importing it again works.
The leaves are unwrapped then.
Has its downs in the re-import process, but the script as a whole is just awesome.
To those also experimenting: triangulate! The .obj you import into the standalone ivygen needs to be triangulated (or better: the objects in your .obj).
I used the triangulate modifier, works peachy. Will do more experimenting, and thanks for the help!
Dennis
thednx
Post by thednx » Wed Mar 06, 2013 7:57 pm
Voila! If at first You dont succeed, try, try again ;-)
Test render, lets see where we go from here!
THANKS!
