Thinking of getting a new CPU
8 posts • Page 1 of 1
baka
Post by baka » Fri Feb 01, 2013 8:39 am
I'm considering getting a 2600k or a 3770k, and would like to know how faster would it render under 3.4.16 compared to a 3Ghz Q6600 . It would be great, if anyone would be kind enough to fire up one of the indigo scenes and give me some solid numbers.
Re: Thinking of getting a new CPU
Post by Zom-B » Fri Feb 01, 2013 9:26 am
Best to do some benchmarking with Erotica & Pins test-scenes, a 5min test should be enough :)
I suggest that the 3770k is 4 times as fast as your actual CPU.
baka
Post by baka » Fri Feb 01, 2013 5:16 pm
I'm getting 420k on erotica and I've seen people get 1100k. but on older versions of indigo. I really want to see some updated results.
Post by PureSpider » Fri Feb 01, 2013 11:55 pm
I just tested with the latest beta (3.6.6) and I am getting ~1350k on the erotica scene with my i7 870.
Post by fused » Sat Feb 02, 2013 12:49 am
I have a i7 3770 (non k) and I get ~2000k in erotica in 3.6.6.
I did crank up the multipliers to the max tho (so it's running at 4.10GHz and a little faster still when turbo mode is on).
With some careful overclocking you can probably get a lot more out of the unlocked 3770k.
Post by fused » Sat Feb 02, 2013 12:51 am
fused wrote:I have a i7 3770 (non k) and I get ~2000k in erotica in 3.6.6.
Also, I had a Q9300 before (which is roughly on par with the Q6600) and if I recall correctly I got ~900k samples per second(probably less, actually) in erotica.
Mor4us
Post by Mor4us » Sat Feb 02, 2013 12:55 am
I'm on that 2600k ;)
@ stock clocking it's doing 1570k in erotica
@ my 24/7 clocking 4.3Ghz it's doing 2100k in erotica
C4D R20 Studio
mad-imagery.com
baka
Post by baka » Sat Feb 02, 2013 3:08 am
thanks for the replies, looks like I really have to buy that 3770k.
