Big request: optional disable texture rendering preview!
- zeitmeister
Hey,
working with really big textures (8000x24000) tremendeosly slows down working with Indigo in C4D.
Could you please implement some sort of "activate/deactivate material preview render" checkbox somewhere?
The auto refresh of these indigo materials lasts way too long...
is something possible?
Or might be a way linking to an alternative, emtpy material preview scene?
Something has to happen here.
Thanks for your answer!
Re: Big request: optional disable texture rendering preview!
Moin Zeiti
Maybe "xsTextureSwitch" is what you need.
Check your mail.
Check your mail.
- zeitmeister
Thank you,
but this doesn't help.
What I want is to prevent Cindigo to render in the material editor, and in the attribute manager... the material previews.
Sorry to interrupt with something different guys, but how about a per texture subsampling tag for preview ? 1/2, 1/4, 1/8 etc. Wouldn't that save performances while allowing for faster previews ? Plus, this doesn't exclude a switch.
- zeitmeister
I presume that simply the export to the material preview scene takes too much time, so I would prefer to interrupt that.
Simply adding a 4th setting for preview quality:
- high
- medium
- low
- off
Should be the easiest way to implement that
- high
- medium
- low
- off
Oh, there's already a quality setting, fair enough
- zeitmeister
Off, I badly need Off!
it is even to define per material, so the heavy guys can be set calm that wayCTZn wrote:Oh, there's already a quality setting, fair enough
Great. I just realised that the 8k square PNG I rendered had a weight of 150MB (it's noisy), that may be one of the reason why I don't like texels much.Zom-B wrote:it is even to define per material, so the heavy guys can be set calm that wayCTZn wrote:Oh, there's already a quality setting, fair enough
Loaded into Indigo it should even take 183,1MB, since textures get loaded as raw pixel dataCTZn wrote:Great. I just realised that the 8k square PNG I rendered had a weight of 150MB (it's noisy), that may be one of the reason why I don't like texels much.
- zeitmeister
Off, Off, Off!
Texel black magic all the same.
Hold on, I think that zeiti is trying to say something
zeitmeister wrote:Off, Off, Off!
- zeitmeister
I need this in junction with the new shaders, especially thin SSS, so badly...
a job is waiting...
please Yves, do your best like always!!
a job is waiting...
