exporter stuck on material
3 posts • Page 1 of 1
littlemissbridget
Post by littlemissbridget » Wed Nov 28, 2012 7:17 am
Hi there,
My exporter seems to get stuck on a material and won't export. In the past I have had a few similar problems, and just imported a different igm file into the material to fix it, but this time doing that is not working. What can I do to remove this material and get my file to export?
Thank you!
Note: I just reopened the file and now it is "stuck" on a different material. This is a huge file with lots of materials, is there anything I can do?
Ruby console:
Error: #<FloatDomainError: NaN>
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1584:in `round'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1584:in `add_normals'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1584:in `collect'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1582:in `collect'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1582:in `add_normals'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:424:in `build_mesh'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/IndigoMeshBuilder.rb:141:in `build_active_mesh'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:756:in `export'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1921
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/skindigo/skindigo_core.rb:1584:in `call'
Re: exporter stuck on material
Post by Whaat » Thu Nov 29, 2012 6:14 am
Hi there,
try going to Window->Model info->Statistics->Fix Problems.
You probably have some bad geometry in your model that is messing with the export.
littlemissbridget
Post by littlemissbridget » Thu Nov 29, 2012 3:19 pm
That did the trick!
Thank you so very much!
Users browsing this forum: DotBot [Bot] and 68 guests
