Hi all,
I have a scene in sketchup with a dozen groups ; when I send them to indigo through Skindigo some goups are not included. It seems kinda random since it happened on 2 different groups that were sent correctly to Indigo otherwise.
My only workaround is to explode the group before hitting the Skindigo render button, but it's not that handy.
Anyone has an explanation for this ?
Hugo.
Skindigo does not export some groups
Re: Skindigo does not export some groups
I had what sounds like a similar problem, and the issue was with the SketchUp layers. The Group was on a layer which was switched on (and so was visible within SketchUp), but when I double clicked into the Group the actual elements were on another layer that was turned off, and so didn't export to Indigo.
Try checking within the group that the elements are all on the correct layer.
Bubs
Bubs
[solved] Re: Skindigo does not export some groups
edit : it was that.
