animation problem!!
Come here for help & support.
3 posts • Page 1 of 1
franky
animation problem!!
Post by franky » Sat Aug 04, 2012 7:22 pm
Hello guys,
I have a problem with exporting an animation.
I found the hidden export button, I set the 'halt'. I set the frames per sec. and if I click export, I get only
1 'name'-meshes.igs file. So I'm a little flabbergasted :(
probably I'm doing something wrong, I only have no idea what, so please help.
I use Indigo Renderer v3.0.14, OS X 64-bit build.
Re: animation problem!!
Post by Zom-B » Sun Aug 05, 2012 2:00 am
First of all use the latest Indigo version 3.4.4 and also latest Exporter for you 3D program.
Since you haven't told anything about what that is, you need to check the Forum by yourself to find it :)
Post by CTZn » Sun Aug 05, 2012 2:09 am
Franky is a SketchUp user, by the activity from his forum profile ;)
Just do what Zom-B says for a starter, Franky. The latest SkIndigo installer is (always) shipping with the Indigo installer.
As for the answer you are seeking it will most probably come from a SU user. Hold on, you are the majority.
