C4D crashes with Terracotta tile floor material
Rich_Art
Post by Rich_Art » Tue Jul 17, 2012 9:44 pm
Hi all,
See topic title. Can anybody test this?
http://www.indigorenderer.com/materials/materials/327
On the above link you can find the material which crashes C4D...
I just have a simple studio setup with 3 area lights a stage object and an object. When I apply this material and hit render C4D crashes instantly...
I'm on C4D R13 Win7 64bits
Peace,
Rich_Art. :wink:
Cinema4D R13 Studio + VrayforC4D + UVLayout Pro + 3DCoat + MOI3D
[FONT=Book Antiqua]Neem ook gerust eens een kijkje in mijn galerij en op mijn Vimeo page
Re: C4D crashes with Terracotta tile floor material
Post by fused » Tue Jul 17, 2012 10:16 pm
Hi Rich_Art,
I am looking into this.
Regards,
Yves
Post by fused » Tue Jul 17, 2012 10:33 pm
Fixed the bug for the next release.
Thank you for reporting this issue!
Regards,
Yves
Rich_Art
Post by Rich_Art » Tue Jul 17, 2012 10:53 pm
YW Yves...
has it to do with the Material scripting Language??
Peace.
Rich_Art. :wink:
Post by fused » Tue Jul 17, 2012 11:11 pm
Rich_Art wrote:YW Yves...
Peace.
Rich_Art. :wink:
It was related to ISL shaders, yes. The bug was causing crashes with very long shaders.
Rather embarrassing bug, so I won't go into detail :)
Rich_Art
Post by Rich_Art » Tue Jul 17, 2012 11:18 pm
Haha, no problem. I now avoid that kind of shaders until the bugfix..
Peace,
Rich_Art. :wink:
Rich_Art
Post by Rich_Art » Fri Jul 27, 2012 9:16 pm
Well with the new release it does not crash anymore but see attachment.
On a cube it doe not look likes the original material (http://www.indigorenderer.com/materials/materials/327) and the surfaces of the cube are separated. (in c4d and in indigo as well)
I have attached the C4D R13 file and the Indigo file.
Peace,
Rich_Art. :wink:
cube_error.zip
(92.3 KiB) Downloaded 340 times
Post by fused » Fri Jul 27, 2012 9:28 pm
Rich_Art wrote:Well with the new release it does not crash anymore but see attachment.
Peace,
Rich_Art. :wink:
Hi Rich_Art,
the problem of the sperated faces is easily solved by setting the phong angle to something > 90° on the cube.
The other problem however is not so easy to solve. This is due to the fact that Indigo for C4D can't import shaders that use textures correctly.
The reason is a bit technical and has to do with the way how Indigo's scene format describes textures (and how they are queried from within the shader). It wouldn't be impossible to work around, but certainly quite tricky.
I have discussed this quite often with OnoSendai and we agreed that the way it currently works is in many ways problematic, but we haven't got around to change the scene file format yet.
This is also the reason why Indigo standalone currently does not support editing of shaders with textures.
edit: actually, it would be possible for you to fix it manually. Let me know if you want me to describe it to you.
Rich_Art
Post by Rich_Art » Fri Jul 27, 2012 9:47 pm
Thanks for the quick reply.
If I set the phong angle more than 90 I get shading errors. See image,
The faces won't get separated indeed...But C4D tries to make the cube round. :-)
If it is not to much work for you.. Otherwise I'll try to make my own material within C4D.. We have a whole range of cool shaders etc to work with...
Peace,
Rich_Art. :wink:
Post by Zom-B » Fri Jul 27, 2012 9:59 pm
Rich_Art wrote:If I set the phong angle more than 90 I get shading errors. See image,
That is because you don't subdiv your mesh mate. Displacement on 1 quad mesh doesn't make that much sense ;)
Ad a Indigo Subdiv Tag on the mesh, Doing so I even always deactivate angle limitation in the phong tag, that works quite well!
Post by fused » Fri Jul 27, 2012 10:04 pm
The attachment Knipsel.JPG is no longer available
Oh, you should also add a Indigo subdivision tag to this object as well, because the material uses displacement. Forgot to mention that :)
If you don't care about the displacement, turn off the displacement channel in the material and set the phong angle back to < 90°.
Rich_Art wrote:If it is not to much work for you.. Otherwise I'll try to make my own material within C4D.. We have a whole range of cool shaders etc to work with...
Peace,
Rich_Art. :wink:
Sure thing :)
4 steps:
1) Extract the pigm. It is just a zip file. 7z should detect that and show the context menu (if you are not using 7z, just change the extension to "zip").
2) Then import the igm (skip this if you alredy imported the pigs).
3) Go to the shader that is assigned to "base-terracota" material's "Colour" channel add the texture that was in the pigm to "Texture 1".
4) In the same shader, look for the line that says
( sample2DTextureVec3( 0 , tint( tile ) ) * 3.0 ) + vec3(0.02)
and replace it with
( sample2DTextureVec3( $tex01$ , tint( tile ) ) * 3.0 ) + vec3(0.02)
And that's it:
Rich_Art
Post by Rich_Art » Fri Jul 27, 2012 10:06 pm
LoL you're right. I just noticed the displacement in one of the materials... Duhhh..
I did some subdividing and delete the Phong tag complete. Now it is ok although the material is not as it is intended..
Peace,
Rich_Art. :wink:
Rich_Art
Post by Rich_Art » Fri Jul 27, 2012 10:15 pm
Sure thing :)
4 steps:
and replace it with
And that's it:
Thanks.. I'll test this....
Peace,
Rich_Art. :wink:
Post by Zom-B » Fri Jul 27, 2012 10:17 pm
Rich_Art wrote:I did some subdividing and delete the Phong tag complete...
No no no, just deactivate the checkbox for the smoothing angle in the phong tag!!
Don't you see the sharp normal edges in your render?!
Rich_Art
Post by Rich_Art » Fri Jul 27, 2012 10:40 pm
No worries guy's.. It is ok now... see image.
Thanks for the help.... I'll try to use this with other shaders as well.
Peace,
Rich_Art. :wink:
Users browsing this forum: No registered users and 132 guests
