Max subdivisions problem in Skindigo
7 posts • Page 1 of 1
Antonis777
Post by Antonis777 » Sun May 20, 2012 11:04 pm
I have a certain problem when applying displacement maps on objects and putting a value (1-10) in max subdivision box. No subdivision smoothing turned on. The meshes are ''broken'' somehow... I'd like to know if I'm doing anything wrong. Thanks.
ninopiamonte
Re: Max subdivisions problem in Skindigo
Post by ninopiamonte » Mon May 21, 2012 1:59 pm
Check the walls if it has enabled exit portal.
Right click, then edit active mesh. Otherwise, unable exit portal.
Antonis777
Post by Antonis777 » Mon May 21, 2012 6:31 pm
No exit portals. Besides there are other meshes ''broken'' too such as the car, the cat etc.
Voytech
Post by Voytech » Tue May 22, 2012 5:40 am
Looks like a displacement scale issue or lack of sufficient subdivision.
Post by CTZn » Tue May 22, 2012 11:05 am
The way the cat is "broken" (cut in two) evocates much an uncontrolled exit portal situation, as Nino suggested.
If you are using displacement make sure to push the related objects by a small amount, that is to say centimeters (0.01m) rather than meters (values equal or superior to 1.0).
Antonis777
Post by Antonis777 » Thu May 24, 2012 5:28 am
All my displacements are 0.003m to 0.02m. I realized also that if I don't put any subdivision value no displacement takes place at all.
Post by CTZn » Thu May 24, 2012 5:53 am
Recently I tried to use SkIndigo further and I was stopped by the assignement of exit portals wich was propagated to surfaces the portals were inferred from; I can not tell much more since I don't use SU much, if at all. I should RTFM I assume :)
Unlike bump mapping, displacement happens on points only; that's why adding more points through subdivisions is necessary to see an effect.
