IES Improvements
IES Improvements
Hi all,
We've been working on improving the IES support in Indigo.
A wider range of IES files are now supported, and some IES parsing problems have been fixed. Indigo should now be able to load any somewhat reasonable IES file.
We've also done some work on optimising the rendering when using IES lights, especially for spotlight-type IES files - see the example renders below. Both renders took 30 s. The top image uses the new IES improvements.
Re: IES Improvements
Well done Nik! Such a vast improvement on sampling IES is really a great news!
tar_gniK
- 3D Software: 3ds Max
Looking good, but at the slight expense of samples/sec?
This are great improvements and together with the general light sampling enhancements you brought Indigo to the next level.
Congratulations and thanks a lot!!
quantity != quality
A better result with less samplestar_gniK wrote:Looking good, but at the slight expense of samples/sec?
quantity != quality
Great! Any enhancement to IES is welcome!
One question: Is it possible to rotate the IES light? E.g. to the ceiling? or toward to a wall?
Can you post the code?
Thank you.
Delle
Thank you.
Delle
Its simply controlled by the normal direction of the polygon that emits it... afaik.delle wrote:One question: Is it possible to rotate the IES light? E.g. to the ceiling? or toward to a wall?
Now that is nice !!!
Looking good! Is that example done with plain pathtracing?
Great improvements!
I would bet it only improves the bidirectionnal modeStompinTom wrote:Looking good! Is that example done with plain pathtracing?
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
Etienne is right on the money, as alwaysgalinette wrote:I would bet it only improves the bidirectionnal modeStompinTom wrote:Looking good! Is that example done with plain pathtracing?
Etienne
