Indigo for Photo.
8 posts • Page 1 of 1
bahamut
Indigo for Photo.
Post by bahamut » Thu Feb 16, 2012 12:09 pm
I'm trying to test indigo in this kind of montage.
What do you think?
the hardest part is to adjust all camera stuff to match the render and photo.
http://zahora.eu – portfolio
http://studio.zahora.eu – photos
JK
Re: Indigo for Photo.
Post by JK » Thu Feb 16, 2012 2:33 pm
Hi (and hi everyone, this is my first post!),
bahamut:
Good job there with the render!
I'm kinda new to Indigo and 3d graph, but from what I know about composition I can tell you that your sun angle is way too perfect. I know when you do a shot you can generally wait for a point of view like that, but still... Also the columns - besides the ivy they are all the same(same texture, size etc.). I don't know what is the soft your using for modelling but with Sketchup you can adjust every texture individually for almost every object. Try to randomize it a bit. The little differences make renders photorealistic I guess. Even if you move one column like 3-5 inches and rotate it vertically by an angle of 0,5 / 1(as I remember columns in any of historical temples werent absolutely straight) you will get more realistic touch. If u go for a too perfect shot everyone can tell you something is wrong there. If you cant get a couple of models that differ one from another in a way that would definetely say it's something individual you can always rescale+rotate+rescale/rotate texture. It sure does the trick for most plants/trees and some objects that come in an array.
The two other things that I can tell is that the shadow of that lady is way too green(try comparing it to shadows cast by columns) and the ivy in the right side of the picture looks like it's flying in the air.
Try reworking that sword in the middle of the composition ;-).
These are just minor things IMO. I'm replying only because I'm trying to do something pretty similar to your work. I hope you'll keep on posting your renders too :-)
I hope my english is understandable!
Cheers!
bahamut
Post by bahamut » Thu Feb 16, 2012 9:06 pm
Thanks for reply.
Yes. I've noticed shade colour difference today morning.
For the ivy, i have used Ivy generator. Is there something different for that kind of purpose? (vegetation simulator)
Sword needs to be reworked for sure.
Regards
Mat
galinette
Post by galinette » Thu Feb 16, 2012 11:17 pm
About the shadow, you could:
- Render a second image by adding a big block that will cast a shadow at same position and bigger than the subject's shadow
- Use that shadow with masks to paint the shadow of the subject.
Then you will have perfect shadow tint matching the tiles.
Also, it's a bit too contrasty/overexposed. Try using reinhard tonemapping or increase turbidity (or both), or use shadow/highlights with a soft such as photoshop
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
bahamut
Post by bahamut » Fri Feb 17, 2012 2:53 am
OK. I'll try like this.
ninopiamonte
Post by ninopiamonte » Fri Feb 17, 2012 3:30 pm
Ok. Can I also request to have bumps on the column & floor,
a little rough, and details on the model... That would make it much photorealistic
pocky
Post by pocky » Tue Feb 28, 2012 11:37 pm
Great render! Looks pretty realistic alreay, though I have to agree, some bumps along the road always add character :D :
bahamut
Post by bahamut » Wed Mar 07, 2012 4:17 am
I'm sorry guys :(
The final file is broken and I don't have time now to this again.
Users browsing this forum: No registered users and 101 guests
