Cannot render out from C4D
10 posts • Page 1 of 1
bieberman
Post by bieberman » Tue Dec 20, 2011 7:42 am
Hi all,
I've downloaded the indigo demo for Mac ( ver. 3), and the C4D plug-in (ver. 3.2.1), when I click on "Render with Indigo" a small window pops up (no contents in it) for a brief moment then disappears. Then I receive a message saying C4D has shut down -- although it remains open and functional.
The Indigo program seems to work properly, but I cannot bring a C4D project into it.
I noticed in an earlier post that someone else had the same problem. I did not see a fix for it.
Any help, please.
Thank you,
Bieberman
My system: Intel Mac running 10.6.7: C4D R13
Re: Cannot render out from C4D
Post by zeitmeister » Thu Dec 22, 2011 12:10 am
Unfortunately I haven't got C4D R13; everything is running fine on R11.5 and 10.6.7.
Do you have an earlier version of C4D to test?
Post by Zom-B » Thu Dec 22, 2011 1:12 am
Check the C4D Console if your export was successful (Shift+F10 on PC, or in the "window" tab on the top of C4D)!
You can define the Export path in the "Indigo Render Settings" tag that you can add to your render settings (like AO and Global illumination).
Now you simply open the exported igs file from Indigo GUI and render.
I hope that helps!
bieberman
Post by bieberman » Thu Dec 22, 2011 4:03 am
Zom -B,
I checked the C4D console as you suggested and it showed the file exported to Indigo. It also showed that Indigo had launched although it hadn't. I opened Indigo manually and tried to import the .igs file created in C4D but all I got was an error message. No luck.
Zeitmeister,
Unfortunately I only have C4D R13.
Thank you both.
Bieberman
Post by Zom-B » Thu Dec 22, 2011 10:16 am
hmm... please try if a simple scene with a cube and a sun, doesn't work for you too.
If not, then please upload the file here so we can check it out :)
bentreality
Post by bentreality » Wed May 16, 2012 6:19 am
i had the same problem trying the demos...
i think it is when you changed the path for the stand alone app.
(i tried rt first and set the path, then changed to indigo render)
is there a way to reset/newly set the path to the stand alone app?
(this is on mac os x)
Post by fused » Wed May 23, 2012 1:34 am
bentreality wrote:i had the same problem trying the demos...
sorry for the late reply.
What version of OSX are you on? 10.5.8?
cowagner
Post by cowagner » Wed Sep 19, 2012 10:16 am
i got the same problem with c4d r13
the indigo render doesnt pop up automatically
I can set the the path and open it manually but it is very unconfortable.
Does anybody know how to solve this problem?
Post by zeitmeister » Thu Sep 20, 2012 5:15 am
Try to find the following file
"cindigoSettings.cfg"
and delete it.
Worked all time since I use Cindigo.
cowagner
Post by cowagner » Thu Oct 11, 2012 8:12 am
thanks, but since version 3.4.8 the problem is solved
