skindigo mesh problem
Come here for help & support.
7 posts • Page 1 of 1
faffo
Post by faffo » Thu Dec 08, 2011 3:43 am
Hi i'm testing indigo with sketchup and i've many problems in mesh like in this one.
In SU i'm showing the hidden geometry and seems all clean... but in render reflections are messy...
Any solution?
Thanks,
Fausto
screenshot from SU
Re: skindigo mesh problem
Post by Whaat » Fri Dec 09, 2011 8:45 am
This is a known issue that is being worked on with very high priority. I plan to have a fix released ASAP. Do you mind posting this SKP for testing purposes? Thanks!
wojtek-w
Post by wojtek-w » Fri Dec 09, 2011 7:53 pm
maybe triangulation would help? You can do it using some plugin or by exporting to .obj format and imprting back to SU.
Post by zeitmeister » Fri Dec 09, 2011 9:50 pm
You should cut the plane rectangular close around the typo to avoid large tri polys.
I know that proper meshflow in sketchup is a pain in the ass... :-)
snorky
Post by snorky » Fri Dec 09, 2011 11:20 pm
zeitmeister wrote:a pain in the ass...
:shock:
Whaat helps us!!!!
:lol:
Post by zeitmeister » Sat Dec 10, 2011 4:01 am
... and you really can't do a simple cut in SketchUp?
If you cut like this, you will avoid large tris and it will render nearly without phong artifacts.
faffo
Post by faffo » Wed Dec 21, 2011 10:23 pm
Thank you very much zeitmeister and all of you for this fast support, i resolved with the simple cuts workaround.
See you soon on forums! :)
