Hello, I have a problem: some geometry does not export properly to Indigo.
To be more specific - it is terrain, made of contours using Sandbox, (lot of triangles) where I made some changes with the Artisan plugin (sculpting). Closing and opening the file again did not help. If it is not clear enough, I can post images.
May it be because the changes are made via plugin, not via common SketchUp tools?
Any ideas how to solve this?
Thank you.
problem exporting
problem exporting
SketchUp 8 / Windows 7 x64 / Indigo 3.0.14 / i7 CPU Q720 @ 1.60 GHz / 4.00 GB RAM / NVIDIA GeForce GT 230M
Re: problem exporting
I don't think so: the plugin doesn't make any magic: it creates basic geometries so there should be no problems after the export. Let's see what it is. Some images of the errors always help thoughmunkey wrote: May it be because the changes are made via plugin, not via common SketchUp tools?
Yes pibuz is right. Plugins should never result in anything other than normal SketchUp geometry, same goes for Artisan.
Please post some images and I'm sure the issue will become very clear so we can help you out.
