Material finder
Material finder
hi!
this is my silly app... to search indigo's materials.
double-click to image or list's row to download
have fun!
have fun!
- Material_Finder.zip
- (109.19 KiB) Downloaded 368 times
Re: Material finder
it works !
Indigo got it, the web site got it, most exporters got it... silly app
- Polinalkrimizei
Re: Material finder
Nice!
This is nice and easy and will actually be useful. Thanks!
Might it be possible to see the igs in the app?
Re: Material finder
CTZn wrote:it works !
sure!!!Polinalkrimizei wrote:Nice!
Re: Material finder
material source added...
Re: Material finder
It doesn't work to me. What I'm doing wrong? Should I place it in Indigo Install directory or what?
Here's the error code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Net.WebException: The remote server returned an error: (404) Not Found.
at System.Net.WebClient.OpenRead(Uri address)
at System.Windows.Forms.PictureBox.Load()
at Material_Finder.Form1.ListBox2_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ListBox.OnSelectedIndexChanged(EventArgs e)
at System.Windows.Forms.ListBox.set_SelectedIndex(Int32 value)
at Material_Finder.Form1.ListBox1_SelectedIndexChanged(Object sender, EventArgs e)
at System.Windows.Forms.ListBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5485 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
Material_Finder
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///E:/Indigo%20Materials/Material_Finder.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 2.0.50727.5491 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Win32 Version: 2.0.50727.5488 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Accessibility
Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Re: Material finder
Tramis... I'm sorry but this project is very old and I don't have source code anymore... and I'm a bad debugger, Why do you prefer this one instead of indigo built-in function?Tramis wrote:It doesn't work to me. What I'm doing wrong? Should I place it in Indigo Install directory or what?
Re: Material finder
No need to apologizesnorky wrote:Tramis... I'm sorry but this project is very old and I don't have source code anymore... and I'm a bad debugger, Why do you prefer this one instead of indigo built-in function?Tramis wrote:It doesn't work to me. What I'm doing wrong? Should I place it in Indigo Install directory or what?
Re: Material finder
Would be great inside the exporter UI's.
