While working on a model with Sketchup/Skindigo, often I change the skindigo resolution to half or double the screen size to test out different settings.
But if I take the model to a machine without skindigo, it still shows the black frame (with no way of changing it?).
How can I remove this, and/or remove all skindigo "stuff" from the sketchup model? (without copying everything into a new file...)
Cheers for any help,
Oliver
Removing all Skindigo Data
Re: Removing all Skindigo Data
Hi,fractal.design wrote:Hi,
Oliver
Go to render settings and press the 'reset camera' button to remove the black frame.
To remove Skindigo data, type the following into the Ruby Console window:
SkIndigo.purge_model (removes settings data)
SkIndigo.purge_mats (removes material data)
