In indigo 3 the GPU is still too little used! why?
Come here for help & support.
spaceuniversal
Post by spaceuniversal » Wed Aug 31, 2011 12:54 am
I v.3.0.12 of Indigo.
Honestly I was very disappointed .. a simple room with 3 mobile (in sketchup) and basic texture made ​​me lose a lot of time ..
My Intel Core i7 920 was squeezed to the maximum (reached 98 degrees constant), the NVIDIA (GTX is a 275) was used very little and despite all this, the rendering time has been very .. I had to stop because I thought in an overheating of the CPU ... :(
I really do not understand .. yet, in your site, talk so much about optimizing with CUDA and GPU ..
and it was a simple frame .. I dare not think of an animation.
there is a lot improve in cuda and open cl
strength and courage :) :roll:
MAttia-italy
Re: In indigo 3 the GPU is still too little used! why?
Post by Headroom » Wed Aug 31, 2011 1:57 am
1. The latest version is 3.0.14
2. Did you use exit portals ?
3. What render mode did you use. Only single directional Path Tracing currently is GPU supported.
4. Did you have window panes in your windows and if so, did you use glass acceleration ?
5. If your CPU gets hot thats an indication that Indigo uses all available CPU resources. That's a good thing!
A little more information about your scene set-up and a few questions from you side may have prevented some of your disappointment and frustration ;-)
Post by CTZn » Wed Aug 31, 2011 3:00 am
Indigo uses GPU acceleration, but it is not a GPU renderer ! It is normal that the CPU throttles the GPU when rendering with Indigo.
Historically GPUs could not always handle all the operations necessary to sustain Indigo rendering methods, things are changing nowadays I bet.
spaceuniversal
Post by spaceuniversal » Wed Aug 31, 2011 5:49 am
CTZn wrote:Indigo uses GPU acceleration, but it is not a GPU renderer ! It is normal that the CPU throttles the GPU when rendering with Indigo.
first of all thanks for the quick replies:). :D
my scene sketch up is very simple: it is a simple room with no windows, with 3 mobile, a bed and a desk made in a very basic and fast, this is a test.
I rendered leaving all the default settings, I checked only the voice that enables the acceleration of my NVIDA GPU.
What do you recommend for a good rendering? I am a beginner. in the future I hope very much that the GPU is used more, but I understand that the present state is very difficult to govern these types of tasks .. by chance know if there is a way to render in the cloud?
Thanks
Post by pixie » Wed Aug 31, 2011 7:18 am
In interior scenes PT isn't as strong as it is on exterior scenes, although I've seen scenes where it surprasses the other modes. I've seen a decent speed bump with this GPU release and am sure that with time, more and more GPU will be used... always with the awesome image quality of Indigo. :)
spaceuniversal
Post by spaceuniversal » Wed Aug 31, 2011 8:09 am
Gazie @ headroom, @ctzn, and @ pixie! I wanted to ask you just one more thing: what is the maximum tolerable temperature for a CPU like the Core i7 when these types of rendering?
1: I have to worry if you get the cpu for 2 minutes even at constant 98 degrees?
2:and rendering complex animations like you as you act? you take lots of breaks?
Post by StompinTom » Wed Aug 31, 2011 8:21 am
spaceuniversal wrote:Gazie @ headroom, @ctzn, and @ pixie! I wanted to ask you just one more thing: what is the maximum tolerable temperature for a CPU like the Core i7 when these types of rendering?
You should check your cooling, because I regularly run my i7 at full capacity overnight without any problems or overheating. It should be able to handle it just fine...
Post by suvakas » Wed Aug 31, 2011 9:00 am
98 degrees is way too high. Something sure is wrong with your cooling.
Post by PureSpider » Wed Aug 31, 2011 9:48 am
suvakas wrote:98 degrees is way too high. Something sure is wrong with your cooling.
Wrong.
98°C are normal under 100% load with intel stock cooling; my i7 870 did that, too.
spaceuniversal
Post by spaceuniversal » Wed Aug 31, 2011 1:04 pm
@StompinTom
you remember at what temperature the sensor signals for your CPU and rendering at night? you can do a check with the freeware "real temp"..
spaceuniversal
Post by spaceuniversal » Wed Aug 31, 2011 1:10 pm
@StompinTom
however it is certainly a problem of cooling. I do I mount a normal intel stock cooling provided by Intel with the Core i7. so I have to mount any other fans ...
Post by suvakas » Wed Aug 31, 2011 5:21 pm
Wrong.
Interesting. My 920 doesn't go over 80 even when 24h under full load with stock cooling.
Post by PureSpider » Wed Aug 31, 2011 11:03 pm
Heck, get some scythe stuff :lol:
No more than 70°C here but I guess I could blow my brain out with that thing :D
Zalman also rocks.
dougal2
Post by dougal2 » Wed Sep 07, 2011 9:11 pm
Intel stock coolers are crap for i7. Mine can easily reach 100 C with the stock cooler, and I don't believe myself that that is a good idea. In fact, neither does the BIOS and it shuts the machine down. I got a little self-contained water/radiator thing for it and now I'm not so scared to use all my horsepower :)
Post by PureSpider » Thu Sep 08, 2011 7:29 am
dougal2 wrote:I got a little self-contained water/radiator thing for it and now I'm not so scared to use all my horsepower :)
Link? 8)
Users browsing this forum: No registered users and 66 guests
