Hi guys
Brand new indigo owner here.
I got a bug report at one of my first tests.
I'm working on a Windows 7 Ultimate 64-bit system
Do you guys know what causes this?
Runtime Error
Re: Runtime Error
Could be a classy "out-of-RAM" issue.
Check the RAM usage of Indigo via taskmanager after starting your scene, then you'll see.
High resolution + multiple Light Layers and high Super Sampling values can eat up a lot of RAM, also high subdivision settings can become quite hungry...
Re: Runtime Error
I'm using indigo RT, and if I've made light layers, it's by mistake.
The task manager says 66mb, but maybe it's low because it doesn't even start.
EDIT: I copied everything over to a new sketchup scene, and now it works!
Re: Runtime Error
Hi 2kemon,
If you still have the sketchup scene, or exported Indigo scene packed as a .pigs,
I'd like to take a look at it, if it causes Indigo to crash.
Can you please email it to support@indigorenderer.com
jose benavides
Re: Runtime Error
hello, I have the same problem, help please
Re: Runtime Error
Please read both comments above your post, and follow the advicejose benavides wrote:hello, I have the same problem, help please
Re: Runtime Error
I think it boils down to creating a new scene and import the buggy scene within, save anew. This may fix.Zom-B wrote:Please read both comments above your post, and follow the advicejose benavides wrote:hello, I have the same problem, help please
