Hello,
I am new here - I hope you can help me with a Spektral-Tutorial in Cinema:
http://www.der-webdesigner.net/tutorial ... rindi.html
I want to get this Spektral effect
This Tutorial was made with Indigo Version: Cindigo 1.0.9 & Indigo 1.0.9
The new Version doesn`t have a null-object with Material Helper Tag - I think it`s because of the old version. I also tried to google for Indigo Version 1.09, but I can`t find.
How can I do it with the latest Indigo-Version - is there another solution.
Thank you
Benberg
Spectral-Tutorial - Material Helper Tag
- Spektral_01.zip
- Here is the file for Cinema 4D 11.5 - thx
- (14.66 KiB) Downloaded 255 times
- pixie
Re: Spectral-Tutorial - Material Helper Tag
you can add an indigo material in Material Manager>File>New Indigo Materialbenberg wrote:Hello,
Thank you
Benberg
Thank you - i did thatpixie wrote:you can add an indigo material in Material Manager>File>New Indigo Material
next Problem is that theres no Indigo Render Settings Objekt: as discribed in the tutorial.
Thank you
Benberg
- Spektral_02.zip
- (19.32 KiB) Downloaded 235 times
Thx - I hink with the material works
Next missing Objectin the latest version:
In the same Tutorial theres a
Render-Setting-Object (Plug-ins -> Cindigo ->Indigo Render Settings)
but I cant find it in latest Version
Thats the last point of the Tutorial - Thx
Hey benberg,
the advanced render settings are now to find in the render Settings of C4D where you add stuff like AO or other effects via right click.
Check out the Cindigo documentation out here: http://www.indigorenderer.com/documentation/cinema4d
And also try the tutorial since it is a nice quickstart for Indigo. Even if that Material is little outdated its still 98% valid and still fresh and warm compared to the Tutorial you found
