I just upgraded to Indigo 3 today and now I keep getting the following error message when I try to use network rendering:
WARNING: Discarded received frame, as incoming scene sequence number 0 does not match current scene sequence number 4.
Does anyone know the cause of this?
Network Rendering Issue
Re: Network Rendering Issue
Hi Aflac,Aflac wrote:I just upgraded to Indigo 3 today and now I keep getting the following error message when I try to use network rendering:
Do you keep getting this error when you continue the network rendering or does it go away after a while?
I seem to have pinpointed the problem, and it's very strange. The problem starts as soon as I switch tonemapping from Reinhard to Camera. I went and checked the slave machines and they were displaying this error message:
Indigo Driver Exception: Already failed loading this scene before, abandoning load. Previous error message: Server denied access to file 'C:\Program Files\Indigo Renderer\data/camera_response_functions/dscs315.txt'.
Thanks for the bug report Aflac,
We will fix in the next release.
I just noticed I also start getting the error if I adjust the gain of a light layer..
