Hello, I have problem with the SKindigo Console. At some materials (not all), if I check the displacement option, it does not save. Everytime I come back to the material it's unchecked.
I'm using Skindigo 2.6.1 / SU8.
Cannot save Displacement.
SketchUp 8 / Windows 7 x64 / Indigo 3.0.14 / i7 CPU Q720 @ 1.60 GHz / 4.00 GB RAM / NVIDIA GeForce GT 230M
Re: Cannot save Displacement.
If you have not linked the displacement map to a valid texture file, displacement will become disabled. Once you select a valid external texture or set the map to 'SketchUp' it should work fine.
That's it, thanks! I'm a bit surprised this happened for some materials from the Indigo Material Library.
