I need some help to export out an animation. When I try i get the following error;
SceneLoaderExcep: Failed to open file 'C:\Users\MYMANGA\Documents\Maxon\test\ball.igs'.
Indigo version: Indigo Renderer v2.6.1, Windows 64-bit build.
Exporter:
Platform:
Author:
Description:
Date created:
Please contact support@indigorenderer.com.
Am using Cinema4d r12 64-bit
Can't export animation
cpu - core i7 2600..................gpu - ASUS GTX 560Ti CU2
RAM - 2*4gb (1333mhz) .....................mobo - GIGABYTE GA-PH67A-UD3-B3
Re: Can't export animation
The Animation was exported correctly, but started wrong!
This is a Cindigo Bug.
Check out the export folder to see all exported frames...
Anyway to render the output you need to use this script atm:
http://www.indigorenderer.com/forum/vie ... =7&t=10247
It works! Thanks a mili....first problem av come across working with indigo....Thanks again.
