Revit Error:The Indigo installation directory was not found.
Come here for help & support.
5 posts • Page 1 of 1
kevnel66
Post by kevnel66 » Fri Jan 14, 2011 8:58 am
I am using Revit 2011 and when i install Indigo Renderer and the Add-In to Revit i am getting an error in revit that says "The Indigo installation directory was not found." This error is preventing me from using the using the Demo
Re: Revit Error:The Indigo installation directory was not fo
Post by fused » Fri Jan 14, 2011 9:16 am
Hey,
after installing the Indigo for Revit plugin you also need to install Indigo Renderer. You can find it here:
http://www.indigorenderer.com/forum/vie ... =1&t=10245
kevnel66
Post by kevnel66 » Fri Jan 14, 2011 9:18 am
i have installed both applications.
Post by fused » Fri Jan 14, 2011 9:48 am
Have you installed Indigo from the same user account from which you're trying to use it?
Indigo for Revit reads a registry key that is written by the Indigo installer. It seems that that key was not written by the installer, or possibly to the wrong user account.
Regards,
Yves
kevnel66
Post by kevnel66 » Fri Jan 14, 2011 10:14 am
That was the problem, our office requires a IT password to do installs so using the IT account password the software thinks i am in the IT user account thus installing it registry info under the IT account. Thanks for the help. :)
