AlainBo
by AlainBo » Sat Dec 18, 2010 4:02 am
Hello,
When I use the Material Editor and click the Pick button to get a material, sometimes it gets the texture of the inside and not the one I see and if I render the scene, it's rendered with the texture it picks and not the texture seen in SU. (Sketchup
Why?
Regards,
wojtek-w
by wojtek-w » Sun Dec 19, 2010 8:36 am
hi AlainBo,
1. make sure that the tip of the picker is over surface You want take material from - edge may have different material assigned.
2. if component (or group) is painted with a material not used inside of it, then indigo may render its external material. f.e. You have box with red walls, but the component (or group) they make is painted green - in that case sometimes indigo renders it green, although You see red in sketchup. It's not a rule, but i observed it few times in my models.
buzzkill
by buzzkill » Wed Mar 16, 2011 11:57 am
AlainBo wrote:Hello,
Why?
Regards,
I have also encountered this. It's just a minor inconvenience. Just zoom in closer on your model, pick the material, then hit "previous" camera view.
marcus3d
by marcus3d » Sat Jul 02, 2011 9:39 am
i have the same problem, i cannot pick the right material.
i am perfectly on the object but it pick other material... why???
i don't see any "previous" camera view.
where is it???
i have indigo 3.0.12 demo version.-.-
C4d R12, W7 64bit, 12 Gb ram, Gtx590 2x1,5Gb
Users browsing this forum: No registered users and 114 guests
