how to fix this, and why?
i use C4D
core i5 8g ram
thanks
Render scene shows vertical or horizontal strips noise
Re: Render scene shows vertical or horizontal strips noise
Probably your scene is way too big; Indigo works in units of metres, so if you have an object at eg (0, 100, 0) then it's 100m from the scene origin.
Very large scenes cause precision problems.
lycium wrote:Probably your scene is way too big; Indigo works in units of metres, so if you have an object at eg (0, 100, 0) then it's 100m from the scene origin.
Yes its work, i change the scene setting to mm, everything just prefect.
thank you so much for your help
hazen
hazen
