Hi all,
I'm curious, I have seen that tag in sketchup generated files. What is the difference with <embedded> ?
Etienne
<embedded_2>
<embedded_2>
Eclat-Digital Research
http://www.eclat-digital.com
Re: <embedded_2>
embedded_2 has shorter xml element names ("pos" became "p", "normal" to "n", etc) and i think in embedded_2 uvs were seperated from the vertices to make the xml file sizes smaller.
edit:
from a testscene
embedded
embedded_2
edit:
from a testscene
embedded
<embedded>
<expose_uv_set>
<index>0</index>
<name>albedo</name>
</expose_uv_set>
<vertex pos="-1.5 0 0" normal="0 -1 0" uv0="0 0" />
<vertex pos="-1.5 0 2" normal="0 -1 0" uv0="0 1" />
<vertex pos="1.5 0 2" normal="0 -1 0" uv0="1 1" />
<vertex pos="1.5 0 0" normal="0 -1 0" uv0="1 0" />
<triangle_set>
<material_name>mat_a</material_name>
<tri>0 2 1</tri>
<tri>0 3 2</tri>
</triangle_set>
</embedded>Code: Select all
<embedded_2>
<expose_uv_set>
<index>0</index>
<name>albedo</name>
</expose_uv_set>
<used_material_name>mat_a</used_material_name>
<used_material_name>mat_b</used_material_name>
<v p="-1.5 0 0" />
<v p="-1.5 0 2" />
<v p="1.5 0 2" />
<v p="1.5 0 0" />
<uvs uv0="0 0" uv1="0 0" />
<uvs uv0="0 1" uv1="0 100" />
<uvs uv0="1 1" uv1="100 0" />
<uvs uv0="1 0" uv1="100 100" />
<t v="0 2 1" uv="0 2 1" m="0"/> <!-- this triangle uses mat_a -->
<t v="0 3 2" uv="0 3 2" m="1"/> <!-- this triangle uses mat_b -->
</embedded_2>Who is online
