Physical sky on INDIGO
7 posts • Page 1 of 1
SCHMUMS
Post by SCHMUMS » Sat Oct 16, 2010 1:10 am
Hello everyone,
I start with INDIGO trial, and I have a problem. I can not bring up a sky or sky physique in INDIGOo. I must certainly have forgotten something. Should there be a tag light on my sky object.
Thank you for avanjce
C4DR11.5-R12 user-Quad core Intel Xenon 2X2,26 GHZ
Zbrush 4
Re: Physical sky on INDIGO
Post by fused » Sat Oct 16, 2010 1:20 am
Hey SCHMUMS,
welcome to Indigo :)
Cindigo does not export the sky object as a physical sky.
You can currently only have the physical sky paired with a sun in Indigo.
To set a sun, go to the Indigo Renderer settings and set a sun object in the "Environment" tab. The sun position on the sky is not determined my the objects position but by its rotation (z axis defines the direction of the sunlight, much like C4Ds infinite light object).
Also, the sun can not be below the horizon.
SCHMUMS
Post by SCHMUMS » Sat Oct 16, 2010 2:23 am
thank you Fused!
it works!
One last question how do appear in the background as a picture of sky or other
Zbrush 4
Post by fused » Sat Oct 16, 2010 6:15 pm
You can set a background material in the Environment tab of the renderer settings. This material must be of type diffuse and should have the emission channel turned on.
Indigo suppors EXR as for hdr images.
But you cannot mix Indigos sun with an environment map at the moment.
SCHMUMS
Post by SCHMUMS » Fri Oct 22, 2010 5:12 am
Fused Hello, thank you for your help, but it does not work. This is what I do:
- I create in my c4d scene as an object back plan
- I create a new material in the channel luminescence I load a HDR.
I assign this material to the object plane back I add a tag light.
After trying to glide through the Environment tab of the preferences Indigo renderer but it does not work.
I attached the screenshot.
thank you in advance
Zbrush 4
SCHMUMS
Post by SCHMUMS » Fri Oct 22, 2010 5:57 am
as for me I found I was not as it should. However I have a problem I've encountered several minutes ... there is a demarcation in the middle of the image, how to address them. Thank you
Zbrush 4
Post by lycium » Fri Oct 22, 2010 11:03 am
Hi SCHMUMS,
the artifact you're getting is due to the very large scene scale. We've improved the precision somewhat since 2.6.1, that could help a little - keep an eye out for the next release!
