camera correction guess vertical or horizontal- possible ?
Come here for help & support.
4 posts • Page 1 of 1
hcpiter
Post by hcpiter » Fri Aug 27, 2010 11:50 pm
hi all !
Is posible use something like camera correction for indigo ? I need use correction for some views but I dont know how or this is possible ?
Re: camera correction guess vertical or horizontal- possible
Post by fused » Sat Aug 28, 2010 12:40 am
Camera correction? Do you maybe mean perspective control or shift lens?
Yes Indigo can do that. Look for a setting in your exporters camera called "Shift up", "Shift right" or similar.
Post by suvakas » Sat Aug 28, 2010 4:32 am
It's called "Shift lens" in Maxigo and you can find it under camera settings.
It's not automatic like camera correction modifier. You have to find a good number by yourself. Just make sure that target of the cam and camera itself are on the same level. (on the same Z value for example)
hcpiter
Post by hcpiter » Sun Aug 29, 2010 5:35 am
Cool thanks guys for help now is better :)
cheers :)
