Sroka8888 Rendering Thread
Re: Sroka8888 Rendering Thread
Post by Oscar J » Wed Apr 20, 2016 8:57 pm
Still awesome though. 8)
Sroka8888
Post by Sroka8888 » Sat Apr 23, 2016 6:10 am
Complete new textures made in DDO (30min)... more details in texture 16bit, more dirts, more scratches, better 16bit roughness/exponent, apeture diffraction from engine.
5min Bidirectional Path Tracing - before 15min / GPU - 40sec (for now without normalmap - beta).
5% color correction after LUT.
Mateusz Sroka
Platige Image - Lighting / Shading / Look Development Artist, Environment Artist
contegufo
Post by contegufo » Sat Apr 23, 2016 7:00 am
Substance Painter?
Post by zeitmeister » Sat Apr 23, 2016 7:17 pm
Quixel Suite...
Great job! My collegue loves that tool too...
Cheers, zeiti
Zalevskiy
Post by Zalevskiy » Sun Apr 24, 2016 4:31 am
Sroka8888 you're crazy, high-quality render 10/10 8)
Post by CTZn » Mon Apr 25, 2016 1:26 am
yep that's brutal !
Sroka8888
Post by Sroka8888 » Mon Apr 25, 2016 7:17 am
I have a lot question :
I use 3ds max to create scene and next export to Indigo app , but i try render in 3ds max using IndigoMax 0.3.12
but i have some problems ...
1. i see difference when i render with Indigo app , and using IndigoMax i set up the same settings in IndigoMax but ... Light is different when i using HDR in the same rotation and scale... subdiv is different
hmmm strange
A - from max without subdiv
B - from max with subdiv
C - export to Ingido app with subdiv
and you see that HRD is in the same rotation and scale so i dont know what is a problem? any help ? this is problem with indigomax version ? or what ?
I prefer render in IndigoMax :) but sometimes i need to use max ....
Next thing i want render animation and when i using 3dsMax and IndigoMax i can save .exr files when i want and save sequence a.0001 a.0002 ......
I see that i can export all frames (sequence) to .igs and mesh and i can add this to render queue but how setup where save frames from sequence automatically ? ... and how setup to save .exr files ? is very important to me.
hmmm indigomax using old version Indigo SDK ?
Mateusz Sroka
Post by Oscar J » Mon Apr 25, 2016 8:59 am
Hi Sroka8888, first of all I'd recommend updating to the latest IndigoMax version. :)
http://www.indigorenderer.com/forum/vie ... =9&t=13772
Unfortunately I can't help any more than that as I'm not a 3DS Max user.
Post by Zom-B » Mon Apr 25, 2016 9:05 am
Also GPU Rendering doesn't support Normal Maps at the moment, but at least v4 can now mix bump map with a Normal map in CPU mode ;)
Sroka8888
Post by Sroka8888 » Mon Apr 25, 2016 9:18 am
ok i know where save image seqence
C:\Users\user\AppData\Roaming\Indigo Renderer\renders any possibility to change this directory ?
ok I know :)
but how setup to save by default no png but .exr ? i dont want change all .igs in notepad :D change <save_tonemapped_exr>true</save_tonemapped_exr>
<save_untonemapped_exr>false</save_untonemapped_exr>
from false to true - I open all files in notepad++ find this line and replace in all files by one click and save all by one click :D so is fast :D
the last indigomax still use odl sdk and in this new version don't work background mode .
Mateusz Sroka
Post by Oscar J » Thu Apr 28, 2016 9:35 am
It's odd because Blender/Blendigo names the output images just like that (.00001, .00002 etc). How are your files named?
Sroka8888
Post by Sroka8888 » Sat Apr 30, 2016 11:20 pm
Network test :)
46/92 CPU Core
10 Supersampling
10000 deph
Motion Blur 0,5
Aperture Diffraction - from engine no post process
Mateusz Sroka
Post by Oscar J » Sun May 01, 2016 1:00 am
Haha, sweet setup. :)
10 supersamplings seems a bit excessive though, unless you're having a lot of fireflies? :shock: Also the transferring time between the network nodes increase exponentially with the supersampling value.
Did you manage to solve your frame output names by the way?
Sroka8888
Post by Sroka8888 » Sun May 01, 2016 1:11 am
I render Aperture Diffraction - from engine no post process , and i see that bigger value of supersampling help a lot denoise this space noise from metals, glare ,flare ... when you render AD from engine you see on black background a lot of flying noise in spec from some highlights :D you see that all this "effects" really makes in engine in render proces.
I will be try do some test without AD and lower value of SS and see how fast render slave response with this value (now is like you write ).
And i want make a stress test :)
+ 8min for frame is great result. In 1200x
1920x ( 16-20min)
I test one scene with lot of texture and have 50M samples/s :D
No , after render i rename using program.
Mateusz Sroka
thesquirell
Post by thesquirell » Sun May 01, 2016 3:23 am
Zom-B wrote:Also GPU Rendering doesn't support Normal Maps at the moment, but at least v4 can now mix bump map with a Normal map in CPU mode ;)
Mixing normal and bump maps? Missed that. Where, how?
