Post by Borgleader » Sun Mar 29, 2009 7:22 am
For crying out loud neo... that image is TOOOOOOO big and its still in png...seriously how many times did we tell you?
SATtva_
Post by SATtva_ » Sun Mar 29, 2009 7:27 am
Anyone uploading 4 Mb PNGs shall be banished into the crater of Mountain Doom. >_<
Post by neo0. » Sun Mar 29, 2009 7:33 am
I can't seem to get any caustics on it either..
Post by fused » Sun Mar 29, 2009 8:18 am
neo0. wrote:I can't seem to get any caustics on it either..
i can clearly see them. try to use smaller emitters (and different tonemapping :D )
edit: ro get rid of the back reflections on the rings add an environment map
Post by CTZn » Sun Mar 29, 2009 9:37 am
Me too am wondering why the rings are not reflecting the clouds in your scene neo0., or trees, or that superb environment needing for true an extendend view ?
The more it goes with you the less I care, it's not time to even have fun with you anymore neo0. As far as I'm concerned I think you are just insulting most people here.
What's the excuse for that, can't you use an image editor ?
edit: besides, if you are not happy with your image post it in another thread.
Post by neo0. » Sun Mar 29, 2009 12:29 pm
Well, it might be because I set the su background color to black. The reason for that is because I wanted to play around with lighting studios and for that, i wanted to eliminate all the other light sources. I also wanted to get dramatic lighting, instead of everything being lit, like it often is the case in most scenes.
I should have provided more info, and no, im not trying to insult anyone. Why would I be insulting people here? Do you think I have some sort of a grudge against people here? Most people have been using indigo since the earliest versions. Look at your registration date. Over a year before mine.
Im very interesting in 3D art/graphics, but it's not exactly a simple field. I have a girlfriend, classes, and i try to keep up my skills at gaming.
Im gonna go ahead and see what kind of tonemapping works best for bringing out those caustics.
Post by CTZn » Sun Mar 29, 2009 1:21 pm
neo0. wrote:Why would I be insulting people here?
Because you seem to ignore what they tell you in a repeated fashion. Oh well, because you were repeating the behaviour. And you just do it again and over.
My turn to ask you: why annoying people repeatedly ? don't you want a better welcoming for your posts ?
[Post was shortened, since you are not a kid I'm not supposed to tell to a mature person what I wrote. Sadly that's based on your says, not on your acts]
Post by neo0. » Sun Mar 29, 2009 1:49 pm
What do I ignore? What are you talking about? :?
Stromberg
Post by Stromberg » Sun Mar 29, 2009 2:06 pm
What do you not ignore is the question, neo0.
You just dont want to listen to what other tells you, amd if you dont want to listen then dont ask questions....
Well for you image, i think you need a smaller light source to make the caustics show up, maybe move it closer so that the light dont loose to much intensity on the way.
Post by neo0. » Sun Mar 29, 2009 2:16 pm
New version with white balance. Now everything doesn't look all yellow.
Stromberg
Post by Stromberg » Sun Mar 29, 2009 2:20 pm
Ok, thats better... but i think the floor should be white.
Maybe make the light even smaller.
I saved out your image and did some things in photoshop.. this is more what i think it should look like.
Post by neo0. » Sun Mar 29, 2009 2:25 pm
Does anyone here know what the correct color temperate for pure white light is?
EDIT : It's 52K. :)
I would be willing to put together a PDF with some examples of color temps. Having numbers associated with colors can seem pretty unintuitive at first and I think it would be helpful. :)
SATtva_
Post by SATtva_ » Sun Mar 29, 2009 7:09 pm
neo0, oh please, please, please, crop your images to a reasonable resolution before posting! Look how little Stromberg did, and how much more informative the image became. It's no use to post gigantic metric planes to show a couple of tiny golden rings in some of their corners. It just stretches forum off the screen making it hard to even read anything.
eulgrand
Post by eulgrand » Sun Mar 29, 2009 9:33 pm
Rendering was way quicker than modelling !
Modeled in SketchUp 6 / Rendered in Indigo 1.1.13
Post by pixie » Mon Mar 30, 2009 1:13 am
If each square is 10cm that's an hell of a ring you have there... perhaps caustics are more evident on smaller sizes...
Users browsing this forum: No registered users and 126 guests
