Indigo 0.9 test 8
WytRaven
Post by WytRaven » Thu Oct 11, 2007 1:48 am
it won't work if you are using test 4 to try to dump with Cool :P
Post by Kram1032 » Thu Oct 11, 2007 2:47 am
That has NOTHING to say, WytRaven...
I did the same, as CoolColJ did, one version later.
My current folder's the 0.9t5's folder, but I simply replaced the old stuff with the new stuff ;)
CoolColJ
Post by CoolColJ » Thu Oct 11, 2007 11:31 am
lol just a folder name, I have mini folders inside with other test versions which I just copy the contents over into the folder and overwrite to use different versions :)
in any case it doesn't work, Indigo thinks I'm trying to render the PNG!
I think it would be better if you can just run indigo normally and when you load up a PNG if spits out the meta data.
Easy for everyone, don't have to bother with command lines!
WytRaven
Post by WytRaven » Thu Oct 11, 2007 2:31 pm
:?: it works for me just fine
CoolColJ
Post by CoolColJ » Thu Oct 11, 2007 2:38 pm
LOL not for me
Indigo Renderer v0.9 test 8, Windows 32-bit Release build.
SSE present.
SSE2 present.
SSE3 not found.
Scene file path: '--dumpmetadata'
Using working directory path ''.
Loading Scene '--dumpmetadata'...
SceneLoaderExcep: failed to open XML doc from path '--dumpmetadata': Failed to open file
Fatal Error: SceneLoaderExcep: failed to open XML doc from path '--dumpmetadata': Failed to open file
SmartDen
Post by SmartDen » Thu Oct 11, 2007 7:23 pm
CoolColJ wrote:LOL not for me
SSE present.
SSE2 present.
SSE3 not found.
you should start
Ana028
Post by Ana028 » Tue Oct 16, 2007 8:40 am
The watermark was a great idea. :wink:
CoolColJ
Post by CoolColJ » Tue Oct 16, 2007 6:15 pm
SSE present.
SSE2 present.
SSE3 not found.
you should start
still doesn't work, a window pops up and dissappears
WytRaven
Post by WytRaven » Tue Oct 16, 2007 6:46 pm
you need to open a console first. So go to your start menu and use the "Run" option. Type "cmd.exe" witout the quotes to launch a console. Navigate (via dos commands) to your indigo folder and then use "indigo_console.exe --dumpmetadata myimage.png".
CoolColJ
Post by CoolColJ » Tue Oct 16, 2007 6:52 pm
gah, much easier to get Indigo to just read the PNG file like normal and output the metadata...
Why even have a switch at all? :?
delic
Post by delic » Tue Oct 16, 2007 11:01 pm
Hi all,
the 64bits build cant load and save .exr on XP64, do I need install something to get it work ?
WytRaven
Post by WytRaven » Wed Oct 17, 2007 12:31 am
No EXR support as of yet in 64Bit Indigo...because one would need to build the EXR stuff in 64Bit too and apparently that's a lot easier said than done.
delic
Post by delic » Wed Oct 17, 2007 12:39 am
So no environnement maps in indigo 64bits ?
Ach, saving exr is not absolutely necessary for me, but hdr environnements is a must for getting realsitic renders ...
zsouthboy
Post by zsouthboy » Wed Oct 17, 2007 1:44 am
Ono got .exr support compiled into the linux version yesterday - dunno if he ever got win64 compiled with it or not.
drBouvierLeduc
Post by drBouvierLeduc » Wed Oct 17, 2007 3:01 am
delic wrote:So no environnement maps in indigo 64bits ? (..)
You can use spherical .float maps with indigo x64.
Use hdrshop to convert latlong .hdr to spherical .float (image -> panorama -> panoramic transformation, then "source image:latitude/longitude" and "destination image:mirrored ball", then "save as -> raw binary floating point".
I agree converting all your maps is a bit of a pain in the ass, and furthermore you have to type each map width in your exporter.
I hope exr support gets back in x64 for windows with indigo 0.9 final.
Users browsing this forum: No registered users and 227 guests
