Material Thread - Post your materials here?
Post by Kram1032 » Sun Oct 21, 2007 9:06 am
this is the current matDB-replacement, until the matDB is finished. - so, no, it's *not
a tutorial, but a place to DL mats
oh, and as long as the material code isn't absolutely *final* (or at least as long as it's not sure, that the next 3 releases wont have any change in the material code), it's not too reasonable to make a tut, anyway.
The per-release-manual should be a good enough reference, *and* you have the exporters. ;)
WytRaven
Post by WytRaven » Sun Oct 21, 2007 6:36 pm
Just so it doesn't get lost:
Schott Glass Material Library for Indigo 1.0.1+
http://www.indigorenderer.com/joomla/fo ... php?t=2838
CoolColJ
Post by CoolColJ » Wed Nov 07, 2007 12:07 pm
Pure water
if you are using Indigo v1.01
then use this - copy and paste it in place of your current water code in the IGS scene file
    <medium>
        <name>MedWater</name>
        <precedence>10</precedence>
        <basic>
            <ior>1.33</ior>
            <cauchy_b_coeff>0.00000</cauchy_b_coeff>
            <regular_tabulated>
               <start_wavelength>0.34E-06</start_wavelength>
               <end_wavelength>0.75E-06</end_wavelength>
               <num_values>83</num_values>
               <values>
               0.0325 0.0264 0.0204 0.018 0.0156 0.0135 0.0114 0.0107 0.0100
               0.0094 0.0088 0.0079 0.0070 0.0060 0.0056 0.0052 0.0054 0.0061
               0.0064 0.0069 0.0083 0.0095 0.0110 0.0120 0.0122 0.0125 0.0143
               0.0130 0.0157 0.0168 0.0185 0.0213 0.0242 0.0300 0.0382 0.0462
               0.0474 0.0485 0.0505 0.0527 0.0551 0.0594 0.0654 0.0690 0.0715
               0.0743 0.0804 0.0890 0.1016 0.1235 0.1487 0.1818 0.2417 0.2795
               0.2876 0.2916 0.3047 0.3135 0.3184 0.3309 0.3382 0.3513 0.3594
               0.3852 0.4212 0.4311 0.4346 0.4390 0.4524 0.4690 0.4929 0.5305
               0.6229 0.7522 0.8655 1.0492 1.2690 1.5253 1.9624 2.5304 2.7680
               2.8338 2.8484
               </values>
            </regular_tabulated>
            <subsurface_scattering>
            <regular_tabulated>
               <values>
               0.0104 0.0098 0.0092 0.0097 0.0082 0.0077 0.0073 0.0069 0.0065
               0.0062 0.0059 0.0056 0.0053 0.0050 0.0048 0.0045 0.0043 0.0041
               0.0039 0.0037 0.0036 0.0034 0.0033 0.0031 0.0030 0.0028 0.0026
               0.0027 0.0025 0.0024 0.0023 0.0022 0.0021 0.0020 0.0019 0.0018
               0.0018 0.0017 0.0017 0.0016 0.0015 0.0015 0.0014 0.0014 0.0013
               0.0013 0.0012 0.0012 0.0011 0.0011 0.0011 0.0010 0.0010 0.0010
               0.0009 0.0009 0.0009 0.0008 0.0008 0.0008 0.0008 0.0007 0.0007
               0.0007 0.0007 0.0006 0.0006 0.0006 0.0006 0.0006 0.0006 0.0005
               0.0005 0.0005 0.0005 0.0005 0.0005 0.0004 0.0005 0.0004 0.0004
               0.0004 0.0004
                </values>
               <phase_function>
          <uniform/>
               </phase_function>
            </subsurface_scattering>
        </basic>
    </medium>
    <material>
        <name>Water</name>
        <specular>
            <internal_medium_name>MedWater</internal_medium_name>
        </specular>
if not you can try this
IOR = 1.33
absorption
red 0.36
green 0.04 to 0.1 (higher is less green, more bluish)
blue 0.0143
values are for what they would be in the IGS file, so may need red/blue flipped around inside the exporter if done from there
scattering
red 0.0007
green 0.002
blue 0.0026
Gamma = 1 for both
and then don't add any bump map to the water mesh and pool surfaces - they slow rendering of caustics a lot!
Post by Whaat » Thu Nov 08, 2007 2:14 am
Thanks CoolColJ! I will be testing it and probably using this for a SkIndigo material preset. Great work!
CoolColJ
Post by CoolColJ » Thu Nov 08, 2007 11:23 am
But wait...there's more :)
water with suspended particles 1mg m-3 concentration level
   <medium>
        <basic>
            <ior>1.33</ior>
            <regular_tabulated>
               <start_wavelength>0.35E-06</start_wavelength>
               <end_wavelength>0.716E-06</end_wavelength>
               <num_values>30</num_values>
               <values>
                0.16 0.165 0.175 0.185 0.19 0.23 0.26 0.28 0.27 0.25 0.24 0.21
                0.18 0.175 0.14 0.125 0.1 0.08 0.075 0.075 0.06 0.07 0.08 0.09
                0.1 0.13 0.15 0.1 0.065 0.03
               </values>
        </basic>
    </medium>
    <material>
        <name>Water</name>
        <specular>
        </specular>
    </material>
only absorption, no scattering values, but I have another water graph to convert that may do the trick, much more dirty though
Only the tabulated version for now, may be able to average out some RGB values
Post by CTZn » Thu Nov 08, 2007 4:12 pm
Thanks thanks thanks CoolColJ ! :P Have more ?
Your examples are precious to get the grip on these new features !
ViennaLinux
Post by ViennaLinux » Wed Dec 19, 2007 10:50 am
indigo really needs a material Database where you can find the xml code and the images/textures for it.
In my eyes it makes no sense to post everything into the forum.
Post by Kram1032 » Wed Dec 19, 2007 10:54 am
The point of this thread is, that it's temporary ;)
The problem is, that the joomla-based site seems to be kinda messy, which slows the progress down to pretty much zero...
dougal2
Post by dougal2 » Wed Dec 19, 2007 10:55 am
ViennaLinux wrote:indigo really needs a material Database where you can find the xml code and the images/textures for it.
this was started but never finished.
also, with the fact that the material XML codes sometimes change, it'd be hard to maintain to produce consistant results across different indigo versions....
...unless, of course, the site was clever and held info like "colour" "exponent" etc and could generate valid code for different indigo versions.... hmmm *thinks*
Post by Kram1032 » Wed Dec 19, 2007 10:57 am
...or you add a version number and the mats are downward compatible, by being converted, before the render starts...
...or both?
dougal2
Post by dougal2 » Wed Dec 19, 2007 11:02 am
might be a worthwhile project for the holidays, I could probably do it in a day or two.
Question is: can I be bothered ?
ViennaLinux
Post by ViennaLinux » Wed Dec 19, 2007 11:02 am
we can make a database with:
Works with version X.XX , X.YY , Y.ZZ etc.
then you can filter ... at least....
joegiampaoli
Post by joegiampaoli » Wed Dec 19, 2007 5:44 pm
Im already working on one, sorry guys (for the past week), but I wanted to surprise you for new years eve. :(
I have it hosted here on my box, still as a test, Im preparing a new indigo material scene file, will unfortunatelly look a lot like another one floating somwhere on the net (if you know what I mean) but I like and understand the setup they use
for the meantime I have the site hosted here, no materials yet, I am still working on web related and finishing the preview scene
here's my link (bare with me I don't have an extremely fast connection)
http://indigo-materials.sytes.net
Remember no www before the domain it's a dynamic ip with page forwarding (for the meantime)
EDIT: heres my material scene (modeling not finished), I know..... it looks awfull lot like the competition, but I have been doing a lot of testing and it's extremely good for what it's needed, let's just stop the modeling, copying, lighting, compostion criticism and let start doing a database which is what indigo and a lot of us need.
Joe Giampaoli
My Indigo Gallery
Stur
Post by Stur » Wed Dec 19, 2007 8:56 pm
It's not that awfull !
In fact, I like it. Maybe the lighting could be improved.
Good luck to achieve your work.
joegiampaoli
Post by joegiampaoli » Wed Dec 19, 2007 9:03 pm
actually light looks cold, but I have to use the E white balance since its the closest to white and will make colors in materials more pure and true, the angle of light mesh has to be right on that spot since it creates some reflected specularity on the grey internal core, which is important, I also have a bigger and softer lightmesh on ceiling for ambient light.
I know some people wont like it, but I really don't care, I just want it to be a functional scene that works with most materials. This has to be done now..... :!: :!: :!:
I'm glad you like it Stur :wink:
Joe Giampaoli
My Indigo Gallery
Users browsing this forum: No registered users and 61 guests
