cindigo 0.8 - beta 1
forget it. i couldnt sleep, so here it is
CINDIGO 0.8 - BETA 1.2
download exporter here (or below)
The file PC versions for R10 and R9. (R10 users will have to rename the "cindigo0.8.1.cdl_R10" to "cindigo0.8.1.cdl")
Mac version will follow soonish.
new in 0.8 - beta 1.2:
* have a look at the console after exporting, it prints errors!
fixed-list 0.8 - beta 1.2:
* texture mapping bug
* not crashing anymore when there is no uvw tag or a material link not set
known bugs/issues 0.8 - beta 1.2:
* sometimes you have to guess the right fields, didnt find out how to hide them yet
* normal problem with .3ds export (=> .3ds export disabled)
* normalization of Vertex Normals is disabled(doesnt work properly), indigo will do that for now
(and it takes very very long)
please post bugs
a good tutorial can be found here (only german and italian, hope someone will translate it to english soon).
still no sample scene
please post bugs
- Cindigo 0.8.zip
- CINDIGO 0.8 beta 1.2
- (262.58 KiB) Downloaded 288 times
Hello!
I downloaded the exporter and done the steps you described in your tutorial. But when I run the start.bat Indigo opens with the Message "could not open inifile.txt" but inifile.txt is definetly in the indigo directory
I use Indigo 0.82 and Cinema4dR10
edit:
works fine if i start indigo.exe directly
one bug i think i found is:
primitives of c4d don't work properly! cubes for example i have to convert to polygon object. spheres not.
when i try to use specular materials i get a "fatal error" look at attachment
but probably only my fault. can someone explain to me how to make reflective materials or glas?
edit:
- fatal.JPG (16.01 KiB) Viewed 4095 times
Marco, that´s awesome !
Please tell us how you did that ! Don´t make me jump into the car and drive all the way to Cologne to get the secret out of you by force ! (It´s just a fifteen minute drive from the north down, but with all that rain coming down at the moment, I´d rather not step out of the house
But more important, as usual the important infos are missing, i.e. cpu and memory setup and render time.
I just yesterday found out what nifty things can be done with place on points and repititions, but I was too hesitant to be so bold an test a poly heavy scene with Indigo. But now, I might just do that !
Michael
Michael
