Indigo Exporter for 0.7t5 - beta release
Locked
Post by fused » Thu Mar 08, 2007 9:41 am
hmmmm...
thought i fixed rotation :(
Pinko5
Post by Pinko5 » Thu Mar 08, 2007 10:06 am
ok tnx wlad ill try
Pinko. :wink:
Post by fused » Thu Mar 08, 2007 11:21 am
a quick testrender for "auto calculate aspect ratio" (15 minutes):
every day a new release :P
INDIGO EXPORTER FOR C4D 0.2.3b
download exporter here (or below)
the file contains "sampleScene.c4d" for everyone who still doesnt know how to setup stuff.
new in 0.2.3b:
* auto calculate aspect ratio from settings in "advanced" tab
* some changes to the render settings tag
* updated "sampleScene.c4d" (grouped with null-objects :D )
known bugs/issues 0.2.3b:
* sometimes you have to guess the right fields, didnt find out how to hide them yet
* env maps are not supported yet
* textures are not supported yet
FIXED-list 0.2.3b:
* FIXED: objects grouped with null-objects get exported now
next things to implement are texure support and layered materials :!:
Indigo Exporter 0.2.3b.zip
Indigo Exporter for C4D 0.2.3b
file contains exporter and "sampleScene.c4d"
(329.45 KiB) Downloaded 386 times
manitwo
Post by manitwo » Thu Mar 08, 2007 11:35 am
fused wrote:every day a new release :P
you are working in lightspeed! thank you!
Post by fused » Thu Mar 08, 2007 11:41 am
actually, compared to my spare time (thanks to being unemployed), i work really slow :)
but, i also want to get this done fast so i can work on my 3d stuff again.
kadajawi
Post by kadajawi » Thu Mar 08, 2007 12:20 pm
Hm... do I need a material tag for each material? When trying to safe my scene C4D crashes...
Post by fused » Thu Mar 08, 2007 12:22 pm
it crashes when you save? or when you export?
which version of c4d do you use?
kadajawi
Post by kadajawi » Thu Mar 08, 2007 12:29 pm
Version 10, when I use plug-ins/indigo exporter/export as ...
Exporting the scene as 3ds or obj file works fine.
Will be trying to get rid of parts of the scene until the crash stops.
Might take a while though... 377 objects, 25000 polygons, several lights, hypernurbs, symetry objects, ...
Camox
Post by Camox » Thu Mar 08, 2007 12:30 pm
WOW :shock: fused you make c4d user happy . Thank you very much ! :wink:
Post by fused » Thu Mar 08, 2007 12:35 pm
@kadajawi:
the solution to your problem is that every object with an object tag needs a cinema material tag
look at the "sampleScene.c4d" to see how to do it correctly
@camox an everybody else who thanked:
it is very appropriate :P
kadajawi
Post by kadajawi » Thu Mar 08, 2007 12:47 pm
I'm studying the sample scene already, what if I don't have an object tag? Are they neccessary? Sorry, had my problems with BLs exporter already. :oops:
Post by fused » Thu Mar 08, 2007 12:56 pm
if you dont have an object tag the object doesnt get exported.
only exceptions are planes, spheres and objects with a light tag (spheres and planes need a cinema material tag).
if you stick to what is shown in sampleScene.c4d you should not have any problems :)
im going to bet now. dont let the bugs get you!
kadajawi
Post by kadajawi » Thu Mar 08, 2007 1:05 pm
Ok, I'll try. That means quite a lot of work though :(
Ah well, good night :)
But only one of the spheres in the sample scene has a material tag?
Hm, I removed the object and material tags from your sample scenes, still exports though Indigo fails to render. I suspect that the tags aren't the problem. Will try to locate the problem.
Edit: I think my tags are the problem...
Ouch. The Light object was a plane and not a polygon object.
Mortal
Post by Mortal » Thu Mar 08, 2007 9:13 pm
Hello!!! I have to change my main proggram (INDIGO) for changing the
exporter to those new versions u upload?
By Mortal and my Metal Band (DarkNeighbour)
www.geocities.com/darkneighbour
Hris
Thank you Fused
Post by Hris » Thu Mar 08, 2007 10:23 pm
Holy Fused! your speed in updating versions is awesome!!!!! if you will keep going this speed, for 1-2 weeks you will create exporter for INDIGO 1.0 :) well...you should to have time for rest man:) but i'm waiting with impatience for your next release :)
Greets from Poland
Hris
Locked
