Voronoi ISL Shader
Re: Voronoi ISL Shader
Post by PureSpider » Sun Apr 01, 2012 9:44 am
Congratulations on being a father now! :!:
dakiru
Post by dakiru » Sun Apr 01, 2012 11:38 am
galinette wrote:I am the father of a little girl named Augustine since yesterday evening!
Welcome to this world, Augustine and congratulations, Etienne!
Post by CTZn » Sun Apr 01, 2012 1:37 pm
Félicitations, et meilleurs voeux à votre petite famille !
Post by Headroom » Sun Apr 01, 2012 1:58 pm
Herzlichen Glückwunsch!
Post by StompinTom » Sun Apr 01, 2012 9:30 pm
Congratulations!
Post by Pibuz » Thu Apr 05, 2012 8:42 pm
Tanti auguri e congratulazioni Galinette!
Post by pixie » Mon Apr 09, 2012 12:59 pm
Congratulations! :)
Voronoi ISL Shader
Post by zeitmeister » Tue Apr 10, 2012 6:00 am
Herzlichen Glückwunsch auch von mir!
Polinalkrimizei
Post by Polinalkrimizei » Thu Apr 12, 2012 6:57 am
Alles Gute und viel Spaß mit Deiner Kleinen!
Post by CTZn » Tue Jan 15, 2013 3:21 am
OnoSendai wrote:You will be able to define shader 'parameters' like so, which will then be available in your shader as pre-defined functions:
We're still working on the code, we'll make a fuss about it when it's done, because it should be pretty cool, and should finally make shaders easily tweakable by artists :)
	<albedo>
				<shader>
          <param>
            <colour3>
              <name>BrickBaseColour</name>
              <description>Base colour for the brick.</description>
              <value>0.6 0.2 0.2</value>
            </colour3>
          </param>
          <param>
            <colour3>
              <name>GroutBaseColour</name>
              <description>Base colour for the grouting.</description>
              <value>0.5 0.5 0.5</value>
            </colour3>
          </param>
          <param>
            <real>
              <name>BrickColourVariation</name>
              <description></description>
              <min>0</min>
              <max>1.0</max>
              <value>0.3</value>
            </real>
          </param>
					<shader>
						<![CDATA[
def brickColour() vec3 :
  paramBrickBaseColour() +
  vec3(
    noise(vec2(0.5 + brickXNum() * 10.0, 0.5 + brickYNum() * 10.0)) * paramBrickColourVariation(),
    0.0,
    0.0
def groutColour() vec3 :
  paramGroutBaseColour()
def eval(vec3 pos) vec3 :
  if(
    (brickX() < grout()) ||
    (brickY() < grout()) ||
    (brickX() > (paramBrickWidth() - grout())) ||
    (brickY() > (paramBrickHeight() - grout()))
    groutColour(),
    brickColour()
					</shader>
				</shader>
			</albedo>
Could I get the full material ? Do you have other cool materials or material bases to share ?
I came to something similar though less elegant, when I remembered about this post. Bricks and parquet.
Post by OnoSendai » Tue Jan 15, 2013 9:27 am
Here it is:
brick_shader_test.igs
(7.62 KiB) Downloaded 308 times
Post by CTZn » Tue Jan 15, 2013 10:43 am
Thank you !
