Oscar's rendering thread
- zeitmeister
Re: Oscar's rendering thread
Yeah!
Cheers, zeiti
Cheers, zeiti
Extremely simple. Smaller, colder and sharper key light, and bigger warmer fill light. White diffuse BG.
A hood. Indigo 4 as per usual - it's truly killer for scenes like this.
- pixie
how does it compare with oldie indigo? I've seen some renders before and they didn't quite match.Oscar J wrote:A hood. Indigo 4 as per usual - it's truly killer for scenes like this.
Looks pretty much identical, unless you're using features that aren't implemented in GPU mode yet (although they are definitely getting fewer).
- zeitmeister
Wow!
Will do a few more of these. This one is an 8 minute render - took about the same time to render out the Material ID pass.
- pixie
How much time would it take to render on CPU? Do you have an idea?Oscar J wrote:Thanks!![]()
Would guess something like two hours or more. The Ms/sec number is about 8 - 10 times better in this type of scenes (the simpler the scene, the better the GPU mode seems to perform), but perhaps more importantly the convergence seems to better and you don't get the checkerboard patterns you sometimes see rendering with Indigo CPU.
Hi
Congratulations for the good work!
A question, Indigo 4 without using the GPU has the same performance of v3.8.30?
Thanks! Will wait for the admins to answer that I think.
More.
More.
Should be a bit faster.contegufo wrote:Hi
- pixie
Wow! clean as a baby bottom's!Oscar J wrote:Thanks! Will wait for the admins to answer that I think.
More.
Damn! you'd slice yourself on the back of that bad boy!
