Blendigo 2.3.x test releases
- aleksandera
Re: Blendigo 2.3.x test releases
There is no motion blur, no matter how hard I try.
- aleksandera
Do you see?
- fish45679.jpg (565.27 KiB) Viewed 7510 times
Very cool scene !!
- Polinalkrimizei
Yep that scene is awesome!
Dougal, nice work, thanks especially for the particle export! Just one request here: could you add support for static particles as well (hair), that would speed up the workflow of creating grass or other randomized instances a lot, cause you wouldn't need to consider the life span of the particles and baking. You see changes in realtime, which gives better control... and children would be nice, too!
- aleksandera
Thank you for compliments, but than doesn't solve my problem
with motion blur
with motion blur
We need a few more details to know if your scene is set up correctly:aleksandera wrote:Thank you for compliments, but than doesn't solve my problem
with motion blur
Do you have the relevant buttons pressed in Blendigo to enable motion blur?
What is your animation frame rate? Camera shutter speed? Exposure Time?
It is possible that if the exposure time is too short, or the shutter speed too fast, or the frame rate too high that you won't see any motion blur effect.
- aleksandera
I hawe increased the exposure time.
It's ok now
Thank you!
It's ok now
Thank you!
- Disabling Subdivision under the mesh options doesn't actually get rid of the subdivision. Tried deleting the temporary scene files but the problem persists. Is there any way to access all the information that the script puts in the .blend file to edit it? Like, is there a way to actually see all the tags that Blendigo saves with the scene file?
EDIT: Scratch that last one, Cap'n. The object was being smooth shaded which was fucking up reflections. All good. Still, is it possible to see all the tags that the script adds to the .blend file?
If you choose 'ID Property Browser' from the help menu you can explore all the custom indigo properties ob objects, materials, scene etc.
And on that note, I'm offlline for a week; snowboarding in Austria
hopefully when I get back I'll have some time to address some issues in this thread.
SLIGHTLY jealousdougal2 wrote:If you choose 'ID Property Browser' from the help menu you can explore all the custom indigo properties ob objects, materials, scene etc.
And on that note, I'm offlline for a week; snowboarding in Austriahopefully when I get back I'll have some time to address some issues in this thread.
StompinTom could you past .blend with some example of grass you've rendered in indigo?
Sure! Give me a little bit of time, very busy today, but I'll try to upload something in the next little bit.ozzie wrote:StompinTom could you past .blend with some example of grass you've rendered in indigo?
Thank you, I'm waitingStompinTom wrote:Sure! Give me a little bit of time, very busy today, but I'll try to upload something in the next little bit.ozzie wrote:StompinTom could you past .blend with some example of grass you've rendered in indigo?
- Borgleader
Was this error ever fixed? Because I just bumped into it... Running Windows 7 x64Godzilla wrote:Ok, I installed the new script for access to particle support, and whenever I open Blender I get the same error message that Doug was getting..
I've tried uninstalling and reinstalling, no luck.Error%Broken installation of Blendigo, please reinstall
Abort
When I go into scripts>render>render with Indigo, the same error..
when I make a new scene... same error.
This is the console:
Users browsing this forum: Google [Bot] and 4 guests
