Indigo 1.1.7
zsouthboy
Post by zsouthboy » Fri Jul 25, 2008 10:56 am
Hey boss, regarding the fun with procedurals: did you happen to make anything useful that you can share, yet?
I was gonna take a whack at say, wood, and if you already have something to modify and play with.. :)
Deus
Post by Deus » Fri Jul 25, 2008 12:48 pm
Ok i try to render with metropolis then. isnt metropolis very bad for outdoor scenes?
Update: Metropolis worked fine.
Post by Whaat » Fri Jul 25, 2008 3:22 pm
Question:
How do you use textured emitters with the new material system? I tried to apply a texture to the <emission> tag and it did not seem to work.
Grimm
Post by Grimm » Fri Jul 25, 2008 9:13 pm
Hey Ono,
I tried to use your shader example in this thread:
http://www.indigorenderer.com/joomla/fo ... php?t=4428
But It doesn't appear to work, I get the following error:
Error: IndigoDriverExcep: SceneLoaderExcep: Found unexpected element 'albedo_shader' in element 'diffuse'. (Around line 116, column 18)
Here is the material I'm trying to use:
        <material>
                <name>ground</name>
                <diffuse>
                        <albedo_spectrum>
                                <rgb>
                                        <rgb>0.8 0.8 0.8</rgb>
                                        <gamma>2.2</gamma>
                                </rgb>
                        </albedo_spectrum>
                        <albedo_texture>
                                <path>../indigo_v1.1.7/testscenes/indigo.jpg</path>
                                <uv_set>uv</uv_set>
                                <exponent>2.200000</exponent>
                                <a>0</a>
                                <b>1</b>
                                <c>0</c>
                        </albedo_texture>
                         <albedo_shader>
                            <![CDATA[
                            def rgbAlbedo(vec3 pos, vec2 uv) vec3 :
                               sample2DTextureVec3(
                                  0,
                                  add(
                                     getTexCoords(0, uv),
                                     vec2(fbm(pos, 10))
                         </albedo_shader>
                </diffuse>
        </material>
I tried futzing (diffuse_shader, shader, etc) with the shader tag to see if I could get it to work but I just got the same error. I'm running this with v1.1.7 in wine on Linux and I initially built the igs file from Blendigo v1.1.5.
Grimm
sugokuGENKI
Post by sugokuGENKI » Fri Jul 25, 2008 10:41 pm
anyone having trouble with networked rendering on 1.1.7?
I get
"IndigoDriverExcep: No emitters inserted in scene."
Perhaps i'm missing something?
i've tried this with the following testscenes and get the same error:
box_emitter_test.igs
airy_disk_test.igs
blend_material_test.igs
Is there a way to 'ignore errors' and just render anyway? I suppose its likely that indigo just isn't seeing any xml at all and the first thing it kicks up about is that there's no emitters.
Using command:
"indigo scenename.igs -n m"
Deus
Post by Deus » Sat Jul 26, 2008 12:26 am
If I turn on the bump in this code i dont get refractions. Whats up? :( Using MLT and BiDir
	<medium>
		<name>watermedium</name>
		<precedence>80</precedence>
			<basic>
				<ior>1.33</ior>
				<cauchy_b_coeff>0</cauchy_b_coeff> <!--0.003-->
					<regular_tabulated>
						<start_wavelength>0.34E-06</start_wavelength>
						<end_wavelength>0.75E-06</end_wavelength>
						<num_values>83</num_values>
						<values>
							0.0325 0.0264 0.0204 0.018 0.0156 0.0135 0.0114 0.0107 0.0100 0.0094 0.0088 0.0079 0.0070 0.0060 0.0056 0.0052 0.0054 0.0061 0.0064 0.0069 0.0083 0.0095 0.0110 0.0120 0.0122 0.0125 0.0143 0.0130 0.0157 0.0168 0.0185 0.0213 0.0242 0.0300 0.0382 0.0462 0.0474 0.0485 0.0505 0.0527 0.0551 0.0594 0.0654 0.0690 0.0715 0.0743 0.0804 0.0890 0.1016 0.1235 0.1487 0.1818 0.2417 0.2795 0.2876 0.2916 0.3047 0.3135 0.3184 0.3309 0.3382 0.3513 0.3594 0.3852 0.4212 0.4311 0.4346 0.4390 0.4524 0.4690 0.4929 0.5305 0.6229 0.7522 0.8655 1.0492 1.2690 1.5253 1.9624 2.5304 2.7680 2.8338 2.8484
						</values>
					</regular_tabulated>
				<subsurface_scattering>
						<regular_tabulated>
							<values>
								0.0104 0.0098 0.0092 0.0097 0.0082 0.0077 0.0073 0.0069 0.0065 0.0062 0.0059 0.0056 0.0053 0.0050 0.0048 0.0045 0.0043 0.0041 0.0039 0.0037 0.0036 0.0034 0.0033 0.0031 0.0030 0.0028 0.0026 0.0027 0.0025 0.0024 0.0023 0.0022 0.0021 0.0020 0.0019 0.0018 0.0018 0.0017 0.0017 0.0016 0.0015 0.0015 0.0014 0.0014 0.0013 0.0013 0.0012 0.0012 0.0011 0.0011 0.0011 0.0010 0.0010 0.0010 0.0009 0.0009 0.0009 0.0008 0.0008 0.0008 0.0008 0.0007 0.0007 0.0007 0.0007 0.0006 0.0006 0.0006 0.0006 0.0006 0.0006 0.0005 0.0005 0.0005 0.0005 0.0005 0.0005 0.0004 0.0005 0.0004 0.0004 0.0004 0.0004
							</values>
					<phase_function>
						<uniform/>
					</phase_function>
				</subsurface_scattering>
			</basic>
	</medium>
	<material>
		<name>water</name>
		<specular>
			<internal_medium_name>watermedium</internal_medium_name>
  			  <!--<bump_map>
		          <uv_set>bump</uv_set>
		          <path>textures/waterbump.jpg</path>
		            <exponent>1.000000</exponent>
			    <b>0.004</b>
         		</bump_map>-->
		</specular>
	</material>
Post by CTZn » Sat Jul 26, 2008 2:39 am
Documentation is the condition, or new features GTF !!!
Thanks for that pdf !
Post by OnoSendai » Sat Jul 26, 2008 6:40 am
zsouthboy wrote:Hey boss, regarding the fun with procedurals: did you happen to make anything useful that you can share, yet?
At some point I'll try and make some procedural terrain, with different colours depending on the elevation etc..
Whaat wrote:Question:
Should work.
Post by OnoSendai » Sat Jul 26, 2008 6:42 am
Grimm wrote:Hey Ono,
That example is obsolete. See albedo_shader_test.igs in the 1.1.7 testscenes dir for an up-to-date example.
Post by CTZn » Sat Jul 26, 2008 7:46 am
Putting simple what I understood about textures indexes, each material can held an arbitrary number of textures, the first having an index number of zero, textures wich in turn can be called by their index number instead of their full name, the whole thing bringing more flexibility imo.
Post by OnoSendai » Sat Jul 26, 2008 7:49 am
CTZn wrote:Putting simple what I understood about textures indexes, each material can held an arbitrary number of textures, the first having an index number of zero, textures wich in turn can be called by their index number instead of their full name, the whole thing bringing more flexibility imo.
yup.
Post by Whaat » Sat Jul 26, 2008 9:37 am
OnoSendai wrote: 2) Set the base_emittance to a nice spectral radiance emission spectrum, like blackbody @ 2800K. Then set emittance as a texture type material parameter, and use the modulating texture for it.
I guess I was having the same issues as BbB. I can't get textured emitters to work either. I am getting the same results as BbB.
Post by Whaat » Sat Jul 26, 2008 9:44 am
OnoSendai wrote: As for getting a fire effect like I can see you're after, the easiest way for that would be for me to allow emission from null materials. I can't think of any killer arguments why this shouldn't be possible, so perhaps I'll add it in.
I don't like the idea of adding attributes to null materials. This kind of defeats the purpose of a null material. Plus, I think it will add unecessary complexity to skindigo.
sugokuGENKI
Post by sugokuGENKI » Sun Jul 27, 2008 12:54 am
Here's my example for blending an emitting material with null.
and there is a mask called layermask.jpg which defines where the emitter exists.
If this doesn't make sense then someone say so and i'll edit it after i've eaten some breakfast.
<material>
		<name>null</name>
		<null_material/>
	</material>
	<material>
		<name>LSimage</name>
		<diffuse>
			<colour>0.7 0.7 0.7</colour>
			<texture>
					<uv_set>mask,image</uv_set>
					<path>layerimg.jpg</path>
					<exponent>10.0</exponent>
			</texture>
			<base_emission>
				<constant>
					<rgb>
						<rgb>100 100 100</rgb>
					<gamma>1</gamma>
					</rgb>
				</constant>
			</base_emission>
			<emission>
				<texture>
				</texture>
			</emission>
		</diffuse>
	</material>
	<material>
		<name>blendmat</name>
		<blend>
			<a_name>null</a_name>
			<b_name>LSimage</b_name>
			<blend_factor>0.5</blend_factor>
			<blend_map>
				<path>layermask.jpg</path>
				<exponent>1.0</exponent>
			</blend_map>
		</blend>
	</material>
Users browsing this forum: No registered users and 99 guests
